Hello GRASS-folks,
the GRASS/XGRASS for LINUX on CD-ROM project is proceeding!
The CD-Image is written and in the testing phase, all I could say,
it behaves well.
This is the last request for submissions of contributed
software and bug-reports for GRASS on LINUX.
I WILL NOT BE ABLE TO TEST ALL GRASS PROGRAMS FOR CORRECT
BEHAVIOUR ON LINUX!!!!!
Definitive contents of the CD:
GRASS 4.1.5 src tree
src.garden tree
src.alpha tree
src.contrib tree (including RIM)
XGRASS except the pixmap-editor completely running
I took the newest pixmap-editor from inria,
which is running well.
MAPGEN an alternative GRASS-MOTIF Inteface based
on XGEN.
GNUPLOT and the GRASS-GNUPLOT interface
SDTS
AGNPS
GRASS-man pages converted to html format, THANK YOU to
Darrel Mcauley!!!!!!
The GRASSU and GRASSP mailing-lists converted to html.
All demonstration-databases, loadable from CD.
Possible additional contents of the CD, depending of free
space and licensing:
KHOROS 2.0.1 I'm currently in negotiation with
Khoral Research on the license fee I have to
pay.
VIS-5D A 3D visualisation system for meteorologic
datasets, but also usable to visualize flow
through a medium (e.g. groundwater flow).
NCSA Dataslicer
NCSA HDF
The GRASS-binaries will be runnable directly from CD, they are
linked from hard-drive to the CD. Drivers for the digitizers
and printers will be installed on the hard-drive. So it is
possible to upgrade to newer programs or add binaries to the
distribution.
The GRASS-program-libriaries will be in the appropriate place, so
You will be able to compile and link additional software.
There will be no LINUX distribution included, so You should have
a minimal LINUX distribution including X. The GRASS binaries,
which are using X are staically linked, so it makes no difference in
using XFree 2.1.x or XFree 3.x., but I'm not familiar with other
X related problems, You might encounter, e.g. problems with fonts,
app-defaults.
You have to use gcc 4.5.26 or newer. The XGRASS binaries are
linked statically to libc 4.5.26, because they will not run with
a newer lib.
To add software You have to use gcc 2.5.8 or newer.
If You have additional suggestions, questions or tips, please
e-mail me directly to holz@oi32.kwu.siemens.de or
holzandr@erls12.kwu.siemens.de. Only if Your mail is of public
interest, please mail to the GRASS mailing-lists.
Greetings from Germany
GERMANY
7 month cold and rainy, 1 month warm, the rest to forget. The elder I become,
the more I hate it.
