Does anyone have or know of a utility program that converts
GRASS4.0 color tables back into the old GRASS3.0 color table
format?
GRASS3.0 color table design used arrays to store a color for each data
value between the minmum and maximum values in the raster map, which is ARC/INFO
recognized format, while GRASS4.0 represent color tables as linear ramps for
intervals of data values. Colors are specified for the endpoints of each
interval.
Since GRASS color files are in simple multi-column plain ASCII format,
you could make changes based on above rules by using a text editor or writing a
small UNIX macro or C program. Let me know if you have any problem to do this.
I'm trying to display GRASS layers in ARC-INFO (gasp! Can I say
that word on this list?) and it appears that the ARC-INFO image
command can only display GRASS layers that have the old color table
format.--------------------
Jerry Ballard TEL: (601) 634-2946
Environmental Characterization Branch
Environmental Laboratory
USACE Waterways Experiment Station
Vicksburg, MS 39180
Song Wang
CAST/NCRI
University of Arkansas
