GRASS4.1.5 on Solaris 2.5 and ps.map
Dear Justin , Malcolm and grassusers:
I maybe could solve the problem concerning "installing GRASS4.1.5 onto
Solaris2.5".
Including problem of my mailed subject:"ps.map on Solaris 2.5". The ps.map
command works normally on Solaris2.5.
I happend to solve my above problem ,but I struggled by that time.
1. copying GRASS4.1.5 into Solaris2.5 on SUN sparc20 which I compiled on
SUN OS 4.1.3(Solaris1.1) ,SUN sparcIPX.
2.editting some file to match the directory-path environment( $GISBASE and
monitorcap ) to the SUN sparc20.
      These are /usr/local.bin/grass4.1 and $GISBASE/etc/monitorcap.
3. generating $GISBASE/dev/fifo0a,fifo0b, ....
    As I could not copy these fifo files, I used the files which I
beforehand generated with compiling procedure on the SUN sparc20.
GRASS4.1.5 binary for Solaris1.1 may work on Solaris2.5.
I sincerely appreciate your helpful suggestions, Justin , Malcolm and
grassusers.
At 11:07 AM 96.10.22 +0000, Justin Hickey wrote:
On Oct 22, 9:52am, Iwao NODA wrote:
And , may I ask you ? I had many warnings as below when I compiled
GRASS4.1.5 with gcc on Solaris2.5.( however the installation was done) Is
that ok ? I worry that grass-commands might generate wrong results.
Thank you for your kindness.
Iwao:
I know most people ignore warnings from compilers and it is true that some of
the warnings can be ignored. However, it has been my experience that warnings
concerning pointers, especially incompatible pointer warnings, require at leas
t
an investigation to see what the problem is.
Iwao Noda
Research Scientist
Forest Management and Economics Laboratory
Kyushu Research Center
Forestry & Forest Products Research Institute
Kurokami 4-11-16, Kumamoto 860, JAPAN
Fax: JAPAN(096)344-5054
Internet : noda12@ffpri-kys.affrc.go.jp
