Grass4.1 Graphics Compilation:
[small note: would people mind hitting return every once in a while
when composing message? :slight_smile: ]
Anantha Prasad (prasad@landcover.inhs.uiuc.edu) writes on 12 May 93:
I have compiled grass4.1 on Sun Sparcstaion 2 under Openwindows Ver3. Before I compiled, I did NOT create /lists/local nor /lists/$ARCH. After I sucessfully compiled the GRASS directory using GISGEN.sun4, I uncommented relevant lines in the /lists/local.example file AND I altered the Gmakefile in $GIS/src/display/devices/XDRIVER/XDRIVER acc. to instructions (for Sun Openwindows).
         I then went to the $GIS/src/display/devices/XDRIVER directory and ran gmake4.1 and got the following error:
cc -O -D_NO_PROTO -I/usr/openwin/include -I/ever/grass4.1/src/include -c SWITCHER.c
./includes.h: 9: Can't find include file X11/Xos.h
./includes.h: 11: Can't find include file X11/Xlib.h
./includes.h: 12: Can't find include file X11/Xutil.h
check /usr/openwin/include/X11 to see if Xos.h, Xlib.h, and Xutil.h
are there. could be that your sys admin didn't installed
the Programmer part(s) of openwin when doing a system upgrade.
--Darrell
