Hi grasshoppers!
We are going to use i.rectify2 to correct
LANDSAT-TM imagery. Has anyone used it?
Any problem? any advice?
Thanks
If you plan to use i.vpoints before i.rectify2, PLEASE let me know if
you have any problem with the ZOOM option for the vector file. I have
had trouble with zooming into the vector map I'm using to select points
from and I want to know if the bug is "local" or worldwide.....
Thank you,
R. Brian Culpepper Research Assistant
Center for Advanced Spatial Technologies (fax) 501 575-3846
Rm. 214 Ozark Hall (work) 501 575-6159
University of Arkansas brian@cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
