I am installing grass4.1 on Sun Sparc 2 Workstation. We have installed Solaris
operating system on our machine and recomiling GRASS4.1
I am encountering some problems. Some of the programs under src src.contrib and
src.alpha are not compiling. It gives the following error. I dont know what is
the problem. Can some of you help me.
The error message is as follows:
cc -s -o /gis/a/grass/grass4.1b/sun4/etc/bin/main/cmd/d.colors OBJ/curses.o OB
J/sigint.o OBJ/set_sigs.o OBJ/get_info.o OBJ/interact.o OBJ/tbl_toggle.o OBJ
/tty.o OBJ/main.o /gis/a/grass/grass4.1/src/libes/LIB/libdisplay.a /gis/a/gras
s/grass4.1/src/libes/LIB/libraster.a /gis/a/grass/grass4.1/src/libes/LIB/libgis
.a -lcurses -ltermlib -lm
ld: fatal: symbol `Def_term' is multiply defined:
(file /usr/ucblib/libcurses.a(curses.o) and file /usr/ccs/lib/libtermli
b.a(setupterm.o));
ld: warning: symbol `ttytype' has differing sizes:
(file /usr/ucblib/libcurses.a(curses.o) value=0x32; file /usr/ccs/lib/l
ibtermlib.a(setupterm.o) value=0x400);
/usr/ccs/lib/libtermlib.a(setupterm.o) definition taken
ld: fatal: File processing errors. No output written to /gis/a/grass/grass4.1b
*** Error code 1
make: Fatal error: Command failed for target n/main/cmd/d.colors'.1b/sun4/etc/b
in
GISGEN failure at STEP: src/display/d.colors
