Dear GRASS-user,
Can GRASS4.1 be used with SOLARIS 2.3 ?
Thank you very much in advance,
Sven Fuhrmann
sven@linus.uni-muenster.de
Dear GRASS-user,
Sven Fuhrmann
In article <9406241606.AA12531@linus.uni-muenster.de>,
sven@linus.uni-muenster.de (Sven Fuhrmann) wrote:
Dear GRASS-user,
Yes - I successfully installed GRASS 4.1 under
SOLARIS 2.3. I did have a problem with the X driver.
d.mon start=x0 gave me an error message. After I set
the LD_LIBRARY_PATH environment variable to
/usr/ucblib d.mon worked OK. I haven't had any
other problems.
John C Talcott talcott@trg.saic.com
Science Applications Intl. Corp. (SAIC)
10260 Campus Point Drive
San Diego CA 92121
(619) 546-6447
In article <Cs5up8.1FMs@yuma.ACNS.ColoState.EDU>,
>other problems.
>John C Talcott talcott@trg.saic.comJohn -- did you compile GRASS4.1 from source or did you use the
pre-compiled binaries? If compiled, what compiler?
Thanks!
I compiled GRASS from source using cc compiler.
San Diego CA 92121
(619) 546-6447
