Grass4.1beta monitor problems
I compiled Grass4.1beta on Sun IPX workstation...without problems...I now have ttrouble running the monitor. I suspect that the problem was while running setup before compiling: it said:
I can't find your X11 include path.
Is X installed on your system? y
Path for X11 include files [RETURN for none] -->/usr/openwin/share/include/X11
Invalid path. Try again.
After several unsuccessful tries, I hit RETURN
XINCPATH=
I can't find your Motif include path.
Path for Motif include files [RETURN for none] -->
XMINCPATH=
I can't seem to find your X Library.
Path to your X Library [RETURN for none] -->/usr/openwin/lib
This is an invalid path. Try again.
I hit return.
When I tried to start the monitor,
GRASS 4.1beta > d.mon x0
Error: could not execute '/ever/grass4.1b/source/sun4/driver/XDRIVER'
What is the solution? Thanks. prasad@ghat.inhs.uiuc.edu
