Two queries.
1. The XDRIVER failed to make in Grass4.1beta on our Sparc 2. The problem
was the file includes.h which looks for non-existent Xol.h, Xlib.h etc in
usr/openwin/include. Our system is standard I think. What is the solution?
At present our solution is simply to use the compiled XDRIVER from Grass4.0
which seems to work perfectly.
2. Has OPENLOOK been abandoned as a format for XGRASS, or are there plans
to enable XGRASS under OPENLOOK in the future? We do not have, nor are we
likely to get MOTIF in the near future. I suspect there are many others out
there who wonder about this.
Grass4.1beta looks good, but I bet it is even better if one can use XGRASS.
Thanks
Mike Hill
Michael J Hill
Research Scientist
CSIRO Pastoral Research Laboratory, Armidale, NSW, Australia,2350.
E-Mail address: mhill@chiswick.anprod.csiro.au
"Michael Hill" (mhill@chiswick.anprod.csiro.au) writes on 9 Apr 93:
though I haven't looked at the source, I can tell you that Xlib.h
should be in $OPENWINHOME/include/X11 and that $OPENWINHOME/include/Xol
is a directory. If you do not have these, complain to your sys admin
(assuming, of course, that you and the sys admin are not the same).
If you have X11R5 installed, look for something like /usr/include/X11.
It's really unfortunate that MOTIF was chosen for this, but last that
I heard, precompiled binaries were available. I doubt that getting
rid of MOTIF in XGRASS is possible at this point. I've simply chosen
to ignore XGRASS/XGEN because of this.
depends. IMO command line interfaces are much more efficient (especially
with more friendly shells, like tcsh, and a moderately fast typing speed).
Interfaces like XGRASS are good for casual users and for showing off
things to "management."
Michael J Hill
--Darrell McCauley
