grass421_on_linux:compilation errors.
At 10:47 AM 12/15/98 +0100, you wrote:
Hi!
I've compiled most of the programs on a
Linux (RedHat 5.1) box, but got some problems with
1. g77 (see below)
Should not gcc take care of F77 ?
It seems that I do not have a g77 compiler, is it not
standard with the Linux distribution?
2. and then another one with run.setup
/usr/local/grass42/src421/src.related/rim
mkdir OBJ.linux
make -f OBJ.linux/make.rules
run.setup
make: run.setup: Command not found
make: *** [rim] Error 127
GISGEN failure at STEP: src.related/rim
Any help?
Thanks
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/alobo
/usr/local/grass42/src421/src.contrib/CERL/misc/m.eigensystem
mkdir OBJ.linux
rm -f OBJ.linux/main.o
g77 -c main.f
make: g77: Command not found
make: *** [OBJ.linux/main.o] Error 127
GISGEN failure at STEP: src.contrib/CERL/misc/m.eigensystem
[root@localhost CMD]# pwd
/usr/local/grass42/src421/src/CMD
/usr/local/grass42/src421/src.garden/answers/src.answers/answers
mkdir OBJ.linux
make[1]: Entering directory
`/usr/local/grass42/src421/src.garden/answers/src.answers/answers'
rm -f OBJ.linux/answers.o
g77 -c answers.f
make[1]: g77: Command not found
make[1]: *** [OBJ.linux/answers.o] Error 127
make[1]: Leaving directory
make: *** [all] Error 1
GISGEN failure at STEP: src.garden/answers/src.answers
/usr/local/grass42/src421/src.garden/answers/raster/r.direct/cmd
mkdir OBJ.linux
`/usr/local/grass42/src421/src.garden/answers/raster/r.direct/cmd'
rm -f OBJ.linux/direct.o
gcc -O2 -m486 -DATT_386 -I/usr/local/grass42/src421/src/include
-DUSE_TERMIO -c direct.c
direct.c: In function `main':
direct.c:77: warning: passing arg 1 of `strcpy' from incompatible pointer
type
direct.c:78: warning: passing arg 1 of `strcpy' from incompatible pointer
type
mv direct.o OBJ.linux/direct.o
rm -f OBJ.linux/cell_open.o
-DUSE_TERMIO -c cell_open.c
mv cell_open.o OBJ.linux/cell_open.o
rm -f OBJ.linux/cell_open_new.o
-DUSE_TERMIO -c cell_open_new.c
mv cell_open_new.o OBJ.linux/cell_open_new.o
gcc -Wl,-s OBJ.linux/direct.o OBJ.linux/cell_open.o
/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a -lm -o
/usr/local/grass42/etc/bin/alpha/cmd/r.direct
/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a(gets.o): In
function `G_gets':
gets.o(.text+0x60): the `gets' function is dangerous and should not be used.
rm -f OBJ.linux/direct_for.o
g77 -c direct_for.f
make[1]: *** [OBJ.linux/direct_for.o] Error 127
GISGEN failure at STEP: src.garden/answers/raster/r.direct
mkdir OBJ.linux
run.setup
/usr/local/grass42/src421/src.garden/grass.rim/s.db.rim/cmd
mkdir OBJ.linux
make[2]: Entering directory
`/usr/local/grass42/src421/src.garden/grass.rim/s.db.rim/cmd'
rm -f OBJ.linux/highlevel.o
-DUSE_TERMIO -c highlevel.c
mv highlevel.o OBJ.linux/highlevel.o
cc -Wl,-s -o /usr/local/grass42/etc/bin/main/cmd/s.db.rim
OBJ.linux/highlevel.o /usr/local/grass42/src421/src/libes/LIB.linux/libgis.a
/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a(parser.o): In
function `interactive_option':
parser.o(.text+0x1331): the `gets' function is dangerous and should not
be used.
rm -f OBJ.linux/s.db.rim.o
g77 -c s.db.rim.f
make[2]: g77: Command not found
make[2]: *** [OBJ.linux/s.db.rim.o] Error 127
make[2]: Leaving directory
make[1]: *** [all] Error 1
`/usr/local/grass42/src421/src.garden/grass.rim/s.db.rim'
GISGEN failure at STEP: src.garden/grass.rim
continued since I forgot: The rim related errors are a result of NOT
compiling rim, which requires specific versions (in the sense of
very-close-to-latest) of gcc/g77.
