Hi everybody-
I started with GRASS5.0 and got stuck in building the XDRIVER. Step
1 through 4 from src/CMD/INSTALL went ok (with some minor changes in
source code ), but now I am little bit confused:
GISGEN reported "DONE generatin binary code", and MAKELINKS was ok,
grass5.0beta started, but d.mon start=x0 failed, because:
1) there was no monitorcap (my fault / easy to fix
2) there was no XDRIVER24...
changing to
src/display/devices/XDRIVER
and starting
gmake5.0beta
failed - as you can see in the attached file. It is a link
problem as far as I can see. Using "-o32" or taking the n32
libs should solve it, but where can I put one or the other?
Changing src/head/head (which is used) had no affect...
Does anybody have any suggestion?
Thanks in advance,
Stephan
Stephan Eickschen Tel. : +49 (0)251 83-34704
Westfaelische Wilhelms-Universitaet Fax. : +49 (0)251 83-36100
Institute for Geophysics
Research Unit of Physical Glaciology email: eicksch@uni-muenster.de
Corrensstrasse 24
48149 Muenster
Germany
http://earth.uni-muenster.de/~eicksch/
(attachments)
XDRIVER24.out (2.18 KB)
