[GRASS5] 5.0.2 ellipsoid selection
Hello,
I updated today to the current CVS version. I saw the changes in proj
stuff. It seems that g.setproj no longer reads from $GISBASE/etc/ellipse.table and datum.table, is it true?
Since I'm working on non-terrestrial bodies' analysis, I have to deal
with 'custom' ellipsoids.
At the moment I'm hardcoding src/libes/proj/ellipse.table and
datum.table but I wonder if there's a more straight way to specify a particular ellipsoid
(specifying directly a and b or a|b and f and so on) so that also other users can do it without the need to recompile.
Just address me and I'll try to give an hand on this.
Alessandro
Alessandro Frigeri
echo '>ti.orebil@flaoeg<' | rev
Hello there
On Mon, 7 Apr 2003, Alessandro Frigeri wrote:
Hello,
It should; what error are you getting or what is going wrong?
datum.table
As far as I can see those files aren't used for anything and I don't know
why they're there. Where are you hardcoding them?
You should just be able to add it to the ellipse.table, or directly in the
PROJ_INFO file. If the most recent version doesn't work then probably in
my changes I have overlooked something and if you can give some more
details on how I can reproduce the problem I will see about fixing it as
soon as possible.
Paul
Hi Paul,
On Mon, Apr 07, 2003 at 08:00:19PM +0100, Paul Kelly wrote:
Hello there
> Hello,
adding:
mars1 "Planet Mars" a=3397000.000 b=3375000.000
to ellipse.table, and:
mars1 "Planet Mars" mars1 dx=0 dy=0 dz=0
to datum.table, g.setproj does not list mars1 as available
datum/ellipsoid.
> datum.table
Sorry, my fault, I meant pj_ellps.c and pj_datums.c... and, yes,
it seems also to me that ellipse.table and datum.table in src/proj are not used.
soon as possible.
Paul
Anyway, I do not get any ellipsoid/datum error on GRASS startup, but
this is true also if I change PROJ_INFO's datum and ellipsoid with a
non-existent one (eg datum: foo ellps: bar).
Alessandro Frigeri
