today I have updated the VERSION handling in 5.1 to have it
independent from 5.0 and to fix a dependency problem, when
5.1 is linked to an uncompiled 5.0 tree.
The version numbers are written correctly by configure from
include/Make/Grass.make.in to include/Make/Grass.make
(that means that the new include/VERSION file is analysed properly).
But now in the current 5.1 CVS version the following files
are not updated properly any more:
configure ...
checking whether to use GLw... no
checking whether to use FreeType... no
checking whether to use NLS... no
creating ./config.status
creating include/Make/Grass.make <- o.k.
creating include/Make/Platform.make <- o.k.
creating include/config.h <- nothing expanded
sed: can't read confdefs.h: No such file or directory <- ???
creating include/version.h <- nothing expanded
creating include/winname.h <- nothing expanded
creating include/config.h <- again?
Maybe someone more expert for configure.in could fix this problem.
A followup to the current configure problem in GRASS 5.1:
The configure.in changes are minimal to the working version 1.12.
But include/config.h in not written properly any more.
Find attached the diff (what I have changed) to the workinf 1.12
version, perhaps someone can tell me the trick.
For now I will revert the change to keep 5.1 in a compilable
state. I still don't understand the problem.
On Thu, Jan 30, 2003 at 11:39:20AM +0100, Markus Neteler wrote:
configure ...
-AC_OUTPUT(include/Make/Platform.make)
+AC_OUTPUT(include/Make/Grass.make include/Make/Platform.make)
+#remove first to avoid link tool problems (5.0 links):
