[GRASS5] 5.3.0 announcement
Hello everyone
The 5.3.0 release is now available at http://grass.itc.it/grass53/source/ (grass-5.3.0.tar.gz), and tagged in CVS with release_15_05_2004_grass5_3_0
I have put a draft of the release announcement in the web CVS module; it can be viewed at:
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/web/announces/announce_grass530.html
I tried to describe some of the major new features in the manner that a commerical software company would advertise their product. Some of them are a bit short on detail at present and I would be grateful if anyone who feels able could add this in. Edit the file directly in the CVS web module or send me a diff. My list of major new features is very subjective and certainly not exhaustive so more can be added. Further details on smaller changes to modules and bugfixes goes in NEWS.html
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass/NEWS.html
Please also test 5.3.0 and report/fix bugs so that the time for 5.3.1 will come soon and bring 5.4.0 closer.
From now on I think there should be a mailing list discussion about any major improvements or new modules: whether they should go into 5.3 or 5.7.
Paul
Kudos to all for the hard work going into 5.3.
I am confused about --with-proj. If I use --with-proj=yes am I instructing GRASS to use an existing installation of Proj.4? If I use --with-proj=no am I giving up any functionality? What would be recommended for creating a Cygwin binary distribution?
Richard Greenwood
www.greenwoodmap.com
Hello Richard
Yes
The main thing I am aware of is you can't use NTv2 distortion grids for datum transformations, as used in Australia, New Zealand and for high accuracy in Canada. Maybe other places. There are some other minor changes discussed on the PROJ.4 mailing list but I'm not sure how important they are.
Actually --with-proj will not work with 5.3.0 on Cygwin due to a bug. I fixed it in CVS yesterday but it is not in 5.3.0. You need to add $(PROJLIB) to the SLIBDEPS line in src/libes/proj/Gmakefile.
It is always good to use the latest version with the latest fixes (parts of the internal GRASS PROJ are quite out-of-date), but using extra shared libraries always causes more complications. libproj.so would need to be in your PATH when running GRASS. An easy way to do this would be to copy it into $GISBASE/lib (init.sh adds this directory to the PATH).
I was building a Cygwin binary distribution of 5.3.0 yesterday but I ran into a problem using the latest GDAL (reported to the list earlier), so it will be a few days at least until it is ready. One point I would make is that
you should use the --without-postgres option to configure and then compile src.garden/grass.postgresql separately at the end using gmake53. This will ensure that nviz works for people who don't have postgresql installed.
Paul
