[GRASS5] 5.3.0 release
Hello
I was thinking if the 5.3.x series is going to be identifiably separate
from the 5.0.x series, we might as well go ahead and remove the internal
copy of PROJ that is in GRASS and make an external PROJ installation an
absolute requirement. This was discussed before and I thought it might not
be a good idea to suddenly introduce the requirement but it would be OK in
the context of 5.3/5.4. Would make the source code package smaller as
well.
Some features such as NTv2 grid transformations are only supported in the
latest PROJ.4.4.7 and not in the private GRASS copy of PROJ.
Maybe the GDAL bridge code could be removed as well and r.in.gdal not
compiled unless GDAL was available at compilation time. Just in general
this would make the linkage to external libraries cleaner I feel.
Are there any objections? I might not be able to finish the PROJ part for
a week or two though if it is going ahead.
Paul
On Thu, Jul 17, 2003 at 08:13:44PM +0100, Paul Kelly wrote:
Hello
well.
For me it sounds good. There is no much point in maintaining a partially
outdated PROJ4 in a 5.3/5.4 release.
One thing we should have in mind is if Debian/SuSe/Mandrake/Redhat/...
have a RPM package and, if not, if we could suggest to add it.
Probably yes. The binary releases could include the libgdal as it is
already done now.
Well, I don't expect any 5.3.x release the next days :slight_smile:
But maybe a 5.0.3, to stop the repeated NVIZ/tcl84 etc questions.
I object!
On Thu, 2003-07-17 at 21:13, Paul Kelly wrote:
Hello
well.
You realise that this is an additional installation hurdle for new
users. Do you feel that your user base is big enough and that your users
are capable of installing all dependency packages on their own? Remember
not all users are developers or really Linux / UNIX literate. I just see
all those queries coming in as soon as this happens. There are enough as
there are with postgres, tcltk versions, and ODBC whose libraries
residing in different locations depending on version and distribution.
It might be trivial for you developers but certainly not for the users.
Well If you go the route of removing PROJ and GDAL from the main
sources, we should consider setting up a package containing all
ancillary code and packages. Even if it is a bit outdated, this might
proove extremely valuable for Newbie's. These ancillary packages might
be things like R, Gstats, alternate GUI's such as QGIS or QGRASS dwg
import module etz. I still think that the biggest problem GRASS has is
the steep learning curve which starts with its installation and
configuration. I frequently have to install the package for fellow GIS
/ RS users.
Just my humble opinion.
Wolfgang
Paul
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Hello Wolfgang
users.
I find it hard to disagree with you as this used to be my opinion as well.
Obviously this is true, although some users might have PROJ installed
already. So I will try and describe what has caused me to change my
opinion more recently.
Most important probably is that I can now compile an external PROJ.4 on
my system. When I first tried (version 4.4.5 I think) I couldn't get it to
compile on SGI/IRIX, so I relied on the internal GRASS copy then. But the
more recent PROJ versions I have had no problem with. It is very quick and
simple to install
tar xvzf proj-4.4.7.tar.gz
cd proj-4.4.7
./configure
make
make install
and then you also have the cs2cs program to reproject points, which is
very useful.
We can put instructions on the website for how to do this, also for
checking that the directory where libproj.so is installed is in
/etc/ld.so.conf on Linux or in LD_LIBRARY_PATH.
In fairness, if a user is not Unix literate, they are not going to get
much out of GRASS, or certainly not use it to anywhere near its full
potential.
I just see all those queries coming in as soon as this happens. There are
enough as there are with postgres, tcltk versions, and ODBC whose libraries
I know this is not really your point but PROJ.4 is a lot smaller and
simpler to install than those other things. Tcl/Tk can take an hour to
compile and install; PROJ is just 5 minutes, or less on a fast machine. I
wouldn't even try installing postgres and ODBC from source.
I suspect most queries would come from using an out-of-date version of
PROJ (this has been the case so far). I will try looking at getting the
configure script to check the version and refuse to continue if it is
older than 4.4.6.
N.B. GDAL isn't contained in the GRASS sources. The change I was proposing
only means GDAL must be installed before compiling r.in.gdal if you want
to use it, rather than adding it as an afterthought. I suspect (have no
proof though) that the gdalbridge mechanism whereby you can compile GRASS
without GDAL and then install it afterwards is sometimes causing
segmentation faults with r.in.gdal because the gdalbridge code may be out
of date---this highlights an advantage of separating out things that are
maintained externally from GRASS.
Yes, but installing these packages wouldn't be any less bother than
installing the latest version. I thought the point was that with the PROJ
built into GRASS the user didn't have to worry about installing it
separately. When PROJ was not being actively maintained for a few years it
was probably a good idea to keep a copy inside GRASS for a while, but now
that it is being maintained again and continuously changing it is just
messy having different versions around and trying to keep them up-to-date.
/ RS users.
What about writing a script that would automatically download the
latest versions of the packages from their respective ftp sites, gunzip,
untar, configure with the correct switches for use with GRASS, compile and
install them all before the main GRASS compilation?
Looks like there are two main reasons for having a separate PROJ:
1) Less developer effort maintaining separate copies and user can take
advantage of latest PROJ capabilities without having to update GRASS.
2) Requires much less space; src/libes/proj directory in GRASS was several
megabytes and all the projection code was compiled into a static library
and linked into every module that uses projection. This makes the binaries
much bigger as well. GRASS 5.1 (to be GRASS 5.7.x) uses shared libaries
and the compiled binaries take a tiny amount of space compared to GRASS
5.0
3) It appears to me generally the way things are done with most Free
software, i.e. all the packages depend on others which have to be
installed first. GRASS didn't used to be like that and is slowly evolving.
Definitely a script to download and install pre-requisite packages as a
pre-install step to GRASS might be a nice idea...
Paul
Hi Paul
I understand your arguments and find them valid. Creating an automatic
install script should receive priorety. This is an issue I have raised
at numerous occasions but developers dont want to spend time on it as
they receive little benefit from it. Its much more exiting implementing
new features. Unfortunately I come from the applied natural sciences
(forestry) and have limited programming skills, but Im getting there.
I would like to spend my efforts on implementing several image
manipulation / analysis features. Mabe the install script is something I
should look at in future but will have to learn alot on the way and this
will take time.
Greetings Wolfgang
On Sat, 2003-07-19 at 12:44, Paul Kelly wrote:
Hello Wolfgang
> users.
simple to install
cd proj-4.4.7
./configure
make
make install
very useful.
potential.
older than 4.4.6.
> / RS users.
5.0
Paul
Hi Wolfgang
On Sat, Jul 19, 2003 at 05:35:36PM +0200, Wolfgang Lueck wrote:
Hi Paul
This is not really true - I have a script which downloads GDAL,
installs it locally, downloads GRASS and generates a package
including GDAL. This could be easily extended to also download
and compile PROJ4.
I have posted that a few times and the automated GRASS 5.1
compilation every Saturday morning is using that script.
Just ask and you can have it :slight_smile:
To improve it to be robust, platform independent etc were
a good idea.
will take time.
You can fetch the scrip (no warranty that it works for you) here:
http://mpa.itc.it/markus/useful/
-> build_grass50binaries.sh
The last GRAS 5.0.2 linux binaries were created using this script.
Be sure to go through it before using, there are some switches
to define if the CVS sources should be downloaded or only updated.
Greetings Wolfgang
> Hello Wolfgang
> > users.
> simple to install
> cd proj-4.4.7
> ./configure
> make
> make install
> very useful.
> potential.
> older than 4.4.6.
> > / RS users.
> 5.0
> Paul
grass5 mailing list
grass5@grass.itc.it
Markus Neteler <neteler@itc.it> http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
> well.
Note that we have to separate questions here in my eyes:
a) What is best for GRASS to maintain
b) and how to provide nice packaging.
As the other branch of this thread shows,
we should care for both.
Still a) should be answered independently from b)
and it is clearly better to have GDAL and PROJ as dynamic
libraries which are not part of the code of GRASS.
Then there are several ways to improve b).
> separate from the 5.0.x series, we might as well go ahead and remove
> the internal copy of PROJ that is in GRASS and make an external PROJ
> installation an absolute requirement.
> in the latest PROJ.4.4.7 and not in the private GRASS copy of PROJ.
partially outdated PROJ4 in a 5.3/5.4 release.
Mandrake 9.1/cooker has a PROJ 4.4.5 RPM pre-packaged. Maybe the fine
folks who did the GRASS package for Mandrake could submit an updated
proj package as well? http://rpms.mandrakeclub.com/rpms/proj.html
Would this Mandrake RPM generic enough to work on Redhat/SuSE?
As mentioned in a previous email, Debian already has proj 4.4.7
packaged. http://packages.debian.org/proj
Neither Redhat 9.0/rawhide or SuSE has a proj RPM as far as I can tell,
but--
wget ftp://ftp.remotesensing.org/pub/proj/proj-4.4.7.tar.gz
tar xzf proj-4.4.7.tar.gz
cd proj-4.4.7
./configure
make
make install
isn't too rough.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I am the grass maintainer for Mandrake, and among other packages related
to grass, I also maintain gdal. gdal-1.1.9 requires an updated proj, but
there were a number of other packages I would like to have updated
(libtiff to 3.6, geotiff to 1.2.0) so I can enable geotiff support in
gdal. As such, I have not uploaded my packages to contrib yet, and the
package blocking this all (libtiff) is in main, so I can't update it. If
we can't update libtiff before release, I will update proj and gdal
(without geotiff support).
However, I can provide proj-4.4.7 (have them available now), gdal-1.1.9
(there is still one issue to fix for this package) etc for Mandrake 9.1,
in fact it is likely necessary to have full functionality from the
grass51 cvs packages available on my site.
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE/HS6LrJK6UGDSBKcRAhqcAKC3YEqX8cjyHMxOyQD7OmtATPyR5gCglE7D
c0KobyU2z7dZwvJolXvUuvE=
=Iis8
-----END PGP SIGNATURE-----
Please click on http://www.cae.co.za/disclaimer.htm to read our
e-mail disclaimer or send an e-mail to info@cae.co.za for a copy.
