Greetings,
Testing out NVIZ with GRASS 5.7.0/5.4.0 here. Looks nice, congratulations on the releases!
With 5.7.0, if I invoke "nviz -q", it works fine. If I start nviz with no arguments, it starts a wish GUI titled "nviz2.2_script", if I choose a raster and hit "Run", I get a dialog stating: "Error: can not find channel named "couldn't execute "nviz_2.2_script": no such file or directory". similarly, if I choose the "Display" - > "Start NVIZ ()" from the Tcl/Tk GUI I get the same error:
can not find channel named "couldn't execute "nviz2.2_script": no such file or directory"
while executing
"fconfigure $msg -blocking 0"
invoked from within
".run invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tk::ButtonUp" line 23)
invoked from within
"tk::ButtonUp .run"
(command bound to event)
I have looked around a bit and I cannot find what would cause the problem. Any hints would be appreciated.
Jeshua Lacock __________________________
Programmer/Owner Phone: 877.240.1364
http://OpenOSX.com Fax: 415.462.6211
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
