[GRASS5] 5.7.0
I think, that there is already enough new functionality in 5.7
for wich users are waiting a long time. It doesn't make much sense
to postpone 5.7.0 for ever, only because of hazy hope that much
more could be done. I want to move forward and release 5.7.0.
It should be something like 5.0 around 1998, that means something
what can be used, but far from stable release.
Certainly >= 5.7.0 will never contain all the functionality from 5.0.0.
To make 5.7 ready for 5.7.0 release, I want to do this:
- category index for vectors (to minimise later format changes)
- disable direct Shapefile and PostGIS support (currently not finished)
- update some missing modules (not all); I have updated status list of
  vector/sites modules (grass51/doc/vector/v.modules.html), my intention
  is to update those with N in third column, however I am not sure about
  statistical modules for sites (s.normal, s.qcount, s.univar, s.windavg,
  s.medp, s.probplt,...), are these modules necessary for 5.7.0?
  You can look at the list (especially N/X/?) and send us your comments.
This doesn't mean that features like PostGIS/Shapefile/OGR cannot be
added during > 5.7.0.
Radim
I agree that an experimental release is fine.
The odd minor version number will tell everybody that it is an
experimental release. A release in that 5.7. line certainly
will be a first step towards a stable release then to be called 5.8.x.
Well it is an experimental development line,
if we clearly say that in the annoucements,
people have no right to be dissappointed.
IMO I don't think src.garden/grass.java/GRASS_libvect.c is worth much effort.
m.in.e00 seems to be worth keeping at a later stage if the effort
of porting is less then adding this to OGR. :slight_smile:
Find this table also here:
http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/v.modules.html
Compare:
http://bugzilla.remotesensing.org/show_bug.cgi?id=159
Maybe a volunteer will contribute this to OGR one day...
Most of the code seems to be already there.
