[GRASS5] 5.7: compilation error management - log file?
Recently the 5.7 Makefile system was changed to continue
on compilation errors. While is is probably a good idea,
it's quite difficult to understand now which modules
were skipped.
Is there a way to implement a error log file support as it
exists for 5.3?
In my case, it was essential; the build would get to lib/form, fail
because I don't have Tcl/Tk 8.4 (Tcl_GetEncoding etc), and that was
the end of the build process.
were skipped.
exists for 5.3?
Try changing this rule (in include/Make/Dir.make):
subdirs:
  @list='$(SUBDIRS)'; \
  for subdir in $$list; do \
      echo $$subdir ; \
      $(MAKE) -C $$subdir; \
  done
to:
subdirs:
      echo $$subdir ; \
      $(MAKE) -C $$subdir || echo $(CURDIR)/$$subdir >> $(GRASS_HOME)/error.log ; \
  done
You'll also need to delete/truncate error.log at the start of the
build.
> were skipped.
> exists for 5.3?
subdirs:
      echo $$subdir ; \
  done
to:
subdirs:
      echo $$subdir ; \
  done
build.
Thanks!
All implemented now in 5.7.
