[GRASS5] 5.7 how to merge polygons with same attribute ?
Hello,
How do I merge polygons with the same value for a given attribute in the
attribute table ?
For example: if I have a map of the world by countries, and for each country
an attribute "continent" in the database table with values such as "Europe",
"North America", etc, how could I create a map showing only the outlines of
the continents ?
Moritz
the attribute table ?
country an attribute "continent" in the database table with values
such as "Europe","North America", etc, how could I create a map
showing only the outlines of the continents ?
maybe
v.extract out=eur -d where="continent='Europe'"
v.extract out=nam -d where="continent='North America'"
v.patch in=eur,nam
for a larger number of items (eg country='Grand Fenwick') I guess you'd
need a script containing a loop.
Hamish
Moritz Lennert wrote:
Hello,
attribute table ?
the continents ?
v.reclass.
Radim
Radim and Hamish,
Hello,
attribute table ?
the continents ?
v.reclass.
Is there a "dissolve common boundaries" flag in v.reclass ?
maybe
v.patch in=eur,nam
Thank you Hamish that does the trick, even though it is a bit tedious when you
have many categories...
A -d flag in v.reclass would probably be the easiest solution.
Moritz
