neteler
November 19, 2004, 4:52pm
1
proposal for 5.7-CVS: make zlib compression instead of RLE the
default setting, probably modifying:
grass57/lib/gis > grep GRASS_INT_ZLIB *
opencell.c: COMPRESSION_TYPE = getenv("GRASS_INT_ZLIB") ? 2 : 1;
Are there objections?
I am, however, not sure, how to apply such change (without
breaking things).
The most obvious problem is that raster maps will be unreadable on
versions of GRASS which pre-date the addition of zlib support.
Also, I don't know whether that feature has received any significant
testing.
breaking things).
COMPRESSION_TYPE = getenv("GRASS_INT_NOZLIB") ? 1 : 2;
neteler
November 22, 2004, 4:04pm
3
Isn't it possible then to
r.compress -u
in the ZLIB-GRASS version and then read it with the older GRASS?
The change is similar to the LZW change some years ago (which went smoothly).
testing.
Time to do that
> breaking things).
Will change here for me at least.
neteler
November 22, 2004, 5:54pm
4
testing.
Here some numbers:
LANDSAT-7 scene:
- compression at 50% of the standard GRASS CELL file compression
57MB color channel -> 28 MB with ZLIB
233MB panchromatic channel -> 127 MB with ZLIB
This is quite an advantage when dealing with lots of remote sensing
data.
- display time (over NFS network in both cases):
beforehand: g.region rast=channel
time d.rast color_channel_standard_compression
real 0m8.957s
user 0m4.850s
sys 0m0.230s
time d.rast color_channel_zlib_compression
real 0m6.011s
user 0m5.080s
sys 0m0.170s
time d.rast pan_channel_standard_compression
real 0m11.500s
user 0m10.690s
sys 0m0.210s
time d.rast pan_channel_zlib_compression
real 0m11.421s
user 0m10.800s
sys 0m0.210s
Interestingly there is less difference the larger the map.
r.compress -u
Yes.
The main issue is that people need to be aware of the change, and to
remember it at relevant times.
[Aside: When I had to deal with Windows users on a regular basis, I
would regularly end up downloading a 1Mb+ email over a 28.8k link only
to find that it contained an MS-Word 8 document. The sender knew that
I could only read version <= 7 documents; they just didn't remember at
the right time.]
