Making Freetype support optional:
... to do so, should I add tons of
#include "config.h"
#ifdef HAVE_FT2BUILD_H
#endif
statements into the following files?
cvsgrass57/display/drivers/lib
command.c
font_freetype.c
Font_get.c
Get_t_box.c
Text.c
cvsgrass57/lib/raster
Font.c
Would appreciate a recommendation how to proceed.
#include "config.h"
#endif
command.c
font_freetype.c
Font_get.c
Get_t_box.c
Text.c
Font.c
display/drivers/lib/Text3.c appears to be the only file which depends
directly upon FreeType. Of the functions in that file:
+ The body of drawMain() should be conditionalised upon
HAVE_FT2BUILD_H, so that the function itself is a no-op if FreeType
isn't available.
+ Other functions which require FreeType should be conditionalised
upon HAVE_FT2BUILD_H, so that the function doesn't exist if FreeType
isn't available.
+ Functions which don't need to be exported (AFAICT, everything except
soft_text_freetype(), soft_text_ext_freetype() and get_text_ext_freetype())
should be declared "static".
The drivers and raster library will support the FONT_FREETYPE and
FONT_FREETYPE_RELEASE operations regardless of whether FreeType was
enabled, except that those operations won't actually work.
> #include "config.h"
> #endif
> command.c
> font_freetype.c
> Font_get.c
> Get_t_box.c
> Text.c
> Font.c
isn't available.
isn't available.
I have made several changes, now it seems to work (please test with and
without Freetype). However, I was not quite lucky with defining functions
static. So I used ifdefs there as well (sorry, I'm still geographer).
I've committed a less invasive fix, that only changes Text3.c and the
Makefile.
