[GRASS5] 5.7: man pages extended
I have modified the build script which generates
the HTML manual pages in 5.7 to add a one-line
description of each module. Like that you can
quickly search for a certain functionality.
So please keep on writing reasonable stuff into
module->description =
:slight_smile:
The online 5.7 manuals will auto-update next Saturday
as usual.
Another useful extension in the C code might be
the introduction of keywords. Per module maybe
2-5 keywords. But yes, a lot of work.
PS: New satellite image fusion script added to 5.7:
    i.fusion.brovey
    (LANDSAT-7 / SPOT / QuickBird, can be easily extended)
Could it just search through the module->description strings? most of
the keywords will already be in there, & if not probably should be.
Adding keywords to every single module is a lot of work...
An exception might be where only one of Delaunay/Voronoi is mentioned in
the description, but I guess you could always rewrite the line it if
need be.
e.g. Debian's "apt-cache search foo" works on the included 2-3 sentence
descriptions.
Hamish
Now online at:
http://grass.itc.it/grass51/manuals/html57_user/index.html
(auto-generated from CVS)
Probably we first have to implement an offline search engine
(something similar as provided by the R-stats where you can search
within local manual pages). Any ideas?
need be.
descriptions.
Nice!
Now online at:
How does the 'apropos' GNU tool do it?
> need be.
> descriptions.
H
apropos is a script which essentially just "grep"s the /usr/man/whatis
file (which is created by the makewhatis script).
