[GRASS5] 5.7: new 'fakestart' concept with demolocation
upon an idea of Radim I have added a small (68k) demolocation
into the 5.7 source code directory.
The 'fakestart' session is now using this demolocation to
generate the HTML documentation (MAN docs derived from that).
Example:
cd vector/v.hull
make
GISRC=/home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/demolocation/.grassrc57 GISBASE=/home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu PATH=/home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/bin:$PATH LD_LIBRARY_PATH=":/home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/lib" /home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/bin/v.hull --html-description | grep -v '</body>' > v.hull.tmp.html ; true
echo "<HR>" >> v.hull.tmp.html
echo "<P><a href=index.html>Help Index</a>" >> v.hull.tmp.html
echo "</body></html>" >> v.hull.tmp.html
mkdir -p /home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/docs/html
mv -f v.hull.tmp.html /home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/docs/html/v.hull.html
install *.png *.jpg /home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/docs/html 2> /dev/null ; true
The visible change here is that GISRC is set. If this works acceptable I'll
remove all the
fakestart = getenv( "GRASS_FAKE_START" );
etc
cruft from the GRASS libs.
This approach seems to be less intrusive (as libs are no longer affected) and
hopefully less fragile as well in case of library changes.
Hopefully also
http://intevation.de/rt/webrt?serial_num=2708
will be cured at the same time.
Future:
This 'demolocation' could be populated with data and then used for
some regression tests.
AFAICT, this won't work if the user building GRASS doesn't own the
source tree, due to G__mapset_permissions().
Mhh.
Maybe, if-user-doesnt-own-source-tree then do this in /tmp?
No idea.
I'm open to different solutions if really needed.
Thinking again:
Note that the demolocation is first installed into dist.$ARCH,
then this one is used (not the one of the source code).
So: in case dist.$ARCH is not writable, the compilation won't
work at all.
grep GISRC ~/grass57/include/Make/Rules.make
        GISRC=$(GISBASE)/demolocation/.grassrc${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR} \
I feel that the above mentioned potential problem with
G__mapset_permissions() doesn't exist (maybe I am wrong).
Thinking again:
I've since noticed that. As the user running "make" will own the copy,
there shouldn't be a problem.
Future:
suggestion for population-
we include an ASCII file with x,y,... point data.
v.in.ascii
v.surf.?
r.contour
would create test point, vector lines, and raster maps from only a small
file in the main tarball. maybe bug points from spearfish or something.
Hamish
Hamish wrote:
Future:
we include an ASCII file with x,y,... point data. v.in.ascii
v.surf.?
r.contour
We could also generate random vector maps (v.random,v.delaunay)
convert them to raster, do the same analysis in raster and vector
and compare results.
Radim
>>Future:
> v.in.ascii
> v.surf.?
> r.contour
> small file in the main tarball. maybe bug points from spearfish or
> something.
maybe that would catch more errors, but would it be harder to reproduce
bugs then?
Hamish
>>Future:
> v.in.ascii
> v.surf.?
> r.contour
I didn't catch your "also", ... of course we could do both.
Hamish
