[GRASS5] 5.7: r.terraflow and gcc 2.96 fails
recently changes were submitted to r.terraflow in 5.3-CVS.
Should it be updated in 5.7 as well?
Currently the automated 5.7 CVS Linux binary snapshot
fails:
bash-2.04$ cd /hardmnt/grass0/neteler/grass51binarybuild/grass51/raster/r.terraflow/
bash-2.04$ make
Makefile:78: warning: overriding commands for target `clean'
../../include/Make/Rules.make:35: warning: ignoring old commands for target `clean'
mkdir -p OBJ.i686-pc-linux-gnu/FLOAT ; true
mkdir -p OBJ.i686-pc-linux-gnu/SHORT ; true
c++ -c -g -O2 -I./IOStream/include -DUSER=\"neteler\" -DNODATA_FIX -D_FILE_OFFSET_BITS=64 -I/hardmnt/grass0/neteler/grass51binarybuild/grass51/include -DELEV_FLOAT main.cc -o OBJ.i686-pc-linux-gnu/FLOAT/main.o
In file included from IOStream/include/ami.h:61,
                 from common.h:49,
                 from main.cc:59:
IOStream/include/empq_impl.h:44:19: ostream: No such file or directory
In file included from plateau.h:50,
                 from water.h:51,
                 from fill.h:46,
                 from main.cc:60:
direction.h:46:19: ostream: No such file or directory
make: *** [OBJ.i686-pc-linux-gnu/FLOAT/main.o] Error 1
bash-2.04$ gcc -v
Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/2.96/specs
gcc version 2.96 20000731 (Red Hat Linux 7.2 2.96-112.7.1)
Probably the recent fixes in 5.3-CVS addressed this problem?
fails:
bash-2.04$ cd
bash-2.04$ make Makefile:78: warning: overriding commands for target
`clean'../../include/Make/Rules.make:35: warning: ignoring old
commands for target `clean' mkdir -p OBJ.i686-pc-linux-gnu/FLOAT ;
true mkdir -p OBJ.i686-pc-linux-gnu/SHORT ; true
-DELEV_FLOAT main.cc -o OBJ.i686-pc-linux-gnu/FLOAT/main.o In file
                 from common.h:49,
                 from main.cc:59:
                 from water.h:51,
                 from fill.h:46,
                 from main.cc:60:
bash-2.04$ gcc -v
No.
gcc 2.96 is missing the <ostream> include header. <ostream.h> is still
available in gcc 3.3 (not sure about 3.4?) for backwards compatibility.
Therefore we have to use #include <ostream.h> and live with the
compiler warning that ostream.h is depreciated.
This has not been reverted yet (for a second time) in either 5.3 or 5.7:
http://freegis.org/cgi-bin/viewcvs.cgi/grass/src.contrib/DUKE/r.terraflow/common.cc
the recent fixes to 5.3 were before the 5.7 copy-mix, they are the same.
see also
http://grass.itc.it/pipermail/grass5/2004-November/015840.html
I'm just about to head out to sea for a while so I can't deal with this now..
Hamish
> fails:
> bash-2.04$ cd
> from common.h:49,
> from main.cc:59:
> from water.h:51,
> from fill.h:46,
> from main.cc:60:
> bash-2.04$ gcc -v
No.
FreeGIS.org
see also
I have submitted the change proposed in above email reference
to 5.7-CVS. We'll see with non-gcc compilers then.
No (more) problems with:
gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-42)
> > flow/
> > from common.h:49,
> > from main.cc:59:
> > directory In file included from plateau.h:50,
> > from water.h:51,
> > from fill.h:46,
> > from main.cc:60:
> still available in gcc 3.3 (not sure about 3.4?) for backwards
> compatibility.
> see also
all the headers without .h should be conditionalized really. THEN we'll
see with non-gcc.
Hamish
