I just tried to compile 5.7 on another machine and got following
problem:
[neteler@wfpovo238 r3.showdspf]$ make
gcc -I/home/neteler/soft/57grass_cvsexp/include -I/home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/include -g -O2 -Wall -Wconversion -Wno-implicit-int -I../../lib/dspf -I -I/usr/X11R6/include -I/home/neteler/soft/57grass_cvsexp/include -I/home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/include \
-o OBJ.i686-pc-linux-gnu/main_ogl.o -c main_ogl.c
main_ogl.c:7:19: Xm/Xm.h: No such file or directory
main_ogl.c:8:21: Xm/Form.h: No such file or directory
In file included from vizual2.h:89,
from vizual.h:1,
from main_ogl.c:18:
But:
[neteler@wfpovo238 r3.showdspf]$ locate Xm.h
/usr/X11R6/include/Xm/Xm.h
[neteler@wfpovo238 r3.showdspf]$ locate Xm/Form.h
/usr/X11R6/include/Xm/Form.h
rpm -qf /usr/X11R6/include/Xm/Xm.h
lesstif-devel-0.93.94-1mdk
head -8 main_ogl.c |tail -3
#define MAIN
#include <Xm/Xm.h>
#include <Xm/Form.h>
Any ideas why the Xm.h is not found?
Note: The main_ogl.c file is linked from 5.3 into 5.7.
Any suggestions?
problem:
from vizual.h:1,
from main_ogl.c:18:
But:
Is it really there? "locate" tells you what was found the last time
that updatedb was run, which may not correspond to the current state
of the filesystem.
I note that the gcc command has the -I/usr/X11R6/include switch; if
that doesn't work, I don't know what will.
> problem:
> from vizual.h:1,
> from main_ogl.c:18:
> But:
of the filesystem.
Yes, I checked it:
[neteler@wfpovo238 r3.showdspf]$ locate Xm/Xm.h
[neteler@wfpovo238 r3.showdspf]$ head /usr/X11R6/include/Xm/Xm.h
* $Header: /cvsroot/lesstif/lesstif/include/Motif-2.1/Xm/Xm.h.in,v 1.33 2002/09/10 22:09...
Ah, found it, it was confused by '-I'. So the Makefile is not
right. After fixing that
GLXContext
is not found. Maybe
/usr/X11R6/include/GL/glx.h
must be included. I have added that to now 5.3's kns_defines.h file.
Tested ok on redhat9 and Mandrake 10.
