I am starting a project soon in which I hope to use GRASS 5.7. Given that an increasing amount of development is shifting to 5.7, I have a set of wishes I want to get out to the list. Perhaps with summer coming around, some can happen.
1. This is the biggest. I wish there was some way in GRASS itself to manage attribute data--especially for vectors. (I'm referring to the new GRASS native dbf format, not the external databases to which GRASS can connect.) v.reclass no-longer has any interactive component. The only way to edit values is to 1) use d.what.vect (which is still buggy and doesn't work after the first time in a GRASS session) on one feature at a time, or 2) use v.digit, again one feature at a time. There is no easy way to even see what values are in the linked attribute table for a vector map now that v.report is gone. I'd like to see v.report come back with options to select fields to report on. However, even more, I'd like to have some kind of simple table display and edit functions in GRASS. The ArcView model of a spreadsheet-like table view, with basic editing and query functions, seems desirable. The lack of any way to manage GRASS attribute data is made worse by the fact that GRASS now has the potential for much richer attribute data and much better query tools, coupled by the strange lack of open-source dbf management tools (like phpMyAdmin for MySQL). Perhaps someone can create a db.manage module.
Along these lines, it would also be nice to get back the interactive versions of r.reclass and r.recode that permit simple editing of category values. It would also be very nice to get back a way to enter or modify raster label strings. These were done under r.support, which is missing from 5.7. There is currently no way to modify raster labels in GRASS 5.7.
In sum, GRASS 5.7 has some new and very powerful ways to query attribute data, but has very minimal means to manage those data--even less so than in 5.0 and 5.3.
2. A flag that sets a default database connection (using the standard GRASS dbf files) for commands that have a database connection option. I'm still having trouble specifying the correct syntax to connect to the database in the new Spearfish data set for 5.7. The flag would make the connection to the database located in $GISBASE/$LOCATION_NAME/$MAPSET/dbf/. Obviously there is more to it than simply specifying this path. I've done that and still am getting a DBMI protocol error. For the GRASS native format, this should be largely seamless.
3. Select buttons for colors, icons, column name, and field value in d.vect. These seem doable as they exist (at least the colors and icons) in the version of d.vect in d.m.
4. A 'clear' button for all the tcltk autogenerated dialogs. I guess this would require a change to g.parser. However, it is a minor but cumulative pain to select long output in the lower window and scroll to delete it--so that I can see what I am doing wrong with the most current version of the command I issue.
5. A return of an interactive r.mapcalc. This is a complex tcltk script. Maybe I can even do this as I work on scripts this summer. However, if someone has a better idea, that would be great.
I sent in several bug reports for GRASS 5.7 to the bug tracker. I can reiterate them to the list if people think it would be good to do so. I just don't want to double people's mail.
Michael Barton
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
