Hello all
I was just thinking that we should add a check for libgdal to configure
and provide a --with-gdal=DIR option. What do people think? I don't know
exactly how this would work or whether there would have to be changes
made to r.in.gdal, but it seems that configure is where we should
determine if libgdal is installed. Is this feasible?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
subject 'unsubscribe grass5'
On Fri, Mar 23, 2001 at 02:37:34PM +0700, Justin Hickey wrote:
Hello all
It's probably a good idea. It requires a little hackery to get the
build system to turn things on/off though.
Eric G. Miller <egm2@jps.net>
> Hello all
Justin / Eric,
I can try to incorporate this if you like. I already have some configure
script for this from MapServer. Also, full GDAL installs include a
gdal-config script (in the spirit of things like gtk-config) which should
make it fairly easy to check for GDAL.
However, if a pre-installed libgdal includes libgrass support, there may
be conflicts trying to use that libgdal in r.in.gdal.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
Hi Frank
> > configure and provide a --with-gdal=DIR option. What do people
> > think? I don't know exactly how this would work or whether there
> > would have to be changes made to r.in.gdal, but it seems that
> > configure is where we should determine if libgdal is installed.
> > Is this feasible?
configure script for this from MapServer.
Yes that would be great since now there is no standard place for
libgdal.
Sincerely,
Bangkok, Thailand
