[GRASS5] again compiling-probs with grass51
Dear developers,
doing a fresh CVS-checkout from grass51 the compilations stops with the
following error:
/daten/software/grass51/include/gis.h:36: warning: `GRASS_copyright'
defined but not used
/daten/software/grass51/include/sqlp.h:145: warning: `newNode' declared
`static' but never defined
gcc -g -L/daten/software/grass51/dist.i686-pc-linux-gnu/lib -o
/daten/software/grass51/dist.i686-pc-linux-gnu/driver/db/pg
OBJ.i686-pc-linux-gnu/column.o OBJ.i686-pc-linux-gnu/cursor.o
OBJ.i686-pc-linux-gnu/db.o OBJ.i686-pc-linux-gnu/describe.o
OBJ.i686-pc-linux-gnu/driver.o OBJ.i686-pc-linux-gnu/execute.o
OBJ.i686-pc-linux-gnu/error.o OBJ.i686-pc-linux-gnu/fetch.o
OBJ.i686-pc-linux-gnu/listdb.o OBJ.i686-pc-linux-gnu/listtab.o
OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/pgexe.o
OBJ.i686-pc-linux-gnu/select.o OBJ.i686-pc-linux-gnu/str.o
OBJ.i686-pc-linux-gnu/table.o
/daten/software/grass51/dist.i686-pc-linux-gnu/lib/libgrass_dbmi.a
/daten/software/grass51/dist.i686-pc-linux-gnu/lib/libgrass_sqlp.a
/daten/software/grass51/dist.i686-pc-linux-gnu/lib/libgrass_dbstubs.a
/daten/software/grass51/dist.i686-pc-linux-gnu/lib/libgrass_dbdialog.a
/daten/software/grass51/dist.i686-pc-linux-gnu/lib/libgrass_gis.a
/daten/software/grass51/dist.i686-pc-linux-gnu/lib/libgrass_datetime.a
-lpq -lcrypt -ltk8.4 -lm -ltcl8.4 -lm \
        -lm -lz
/usr/lib/gcc-lib/i486-suse-linux/3.2/../../../../i486-suse-linux/bin/ld:
cannot find -lpq
collect2: ld returned 1 exit status
make[3]: ***
[/daten/software/grass51/dist.i686-pc-linux-gnu/driver/db/pg] Fehler 1
make[3]: Verlassen des Verzeichnisses
»/daten/software/grass51/db/drivers/postgres«
make[2]: *** [subdirs] Fehler 1
make[2]: Verlassen des Verzeichnisses
»/daten/software/grass51/db/drivers«
make[1]: *** [subdirs] Fehler 1
make[1]: Verlassen des Verzeichnisses »/daten/software/grass51/db«
make: *** [default] Fehler 1
holl@server:/daten/software/grass51>
the postgres-libs and postgres-includes were given during configuration
and point to /usr/local/pgsql/[lib, include]
the system:
Suse linux 8.1
grass5 CVS from 15/05/03
postgres: 7.3.2
Could anybody help me out of this ?!
Thanks for your help
  Stephan Holl
Stephan Holl
GnuPG Key-ID: 11946A09
On Thursday 15 May 2003 02:42 pm, Stephan Holl wrote:
Dear developers,
following error:
        -lm -lz
cannot find -lpq
I think that $(PQLIBPATH) is missing in rules, try to change Makefile from:
$(DRIVER): $(ARCH_OBJS)
   $(CC) -g $(LDFLAGS) -o $@ $(ARCH_OBJS) $(LIBES) $(CRYPTLIB) $(TCLTKLIBPATH) $(TCLTKLIBS) \
              $(MATHLIB) $(XDRLIB)
to
   $(CC) -g $(LDFLAGS) -o $@ $(ARCH_OBJS) $(PQLIBPATH) $(LIBES) $(CRYPTLIB) $(TCLTKLIBPATH) $(TCLTKLIBS) \
Radim
At Thu, 15 May 2003 16:51:25 +0200 Radim Blazek wrote:
Hello Radim,
to
your suggested rule did the trick!
Thank you very much
cheers
  Stephan
Stephan Holl
