[GRASS5] Algorithm i.rectify[2] ?
Hi again,
a colleague of mine wanted to know how pixel values are treated
in i.rectify[2]. Is it a nearest neighbour algorithm or does it
calculate an average of neighboured pixels if they fall into one
resulting cell? To be honest, I don't understand this from the
sources.
Once we know a note should be added into the related html pages
(of course I can do that).
Thanks for any help,
subject 'unsubscribe grass5'
It is nearest neighbour only.
I looked into this at some past point, around version 4.1/4.2, I think.
I doubt anyone has changed it.
Angus.
Markus Neteler wrote:
Hi again,
sources.
Hi Angus,
thanks for clarification. What do you think: Can we live with that?
Probably an interpolating algorithm would produce smoother results?
But I am not sure what's preferred.
Regards
> Hi again,
> sources.
> Markus
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
Markus, et al.:
  My understanding of interpolation algorithms is that a different one is
most appropriate for different types of data. For example, whether the data
are regularly spaced (as on a grid) or randomly spaced. Also, whether each
measured point represents an actual maxima or minima, or is an estimate.
  For example, elevation readings in the Real World are usually randomly
spaced, and each recorded value is probably not a local high- or low-point.
Therefore, an inverse-distance-weighted interpolation algorithm that puts
the fitted line/surface slightly above each maximum point (and slightly
below each minimum point) produces a more accurate estimatation of the true
surface.
  On the other hand, if you are interpolating measured chemical values (say,
in soils in a field) along a regular grid, a nearest neighbor interpolation
algorithm that fits the line/surface through each point produces a better
representation of the spatial distribution of measured values.
  I've not looked at photo-rectification in more than a couple of years, so
I cannot suggest off-hand just what would be best here. There are, of
course, more interpolation algorithms that ought to be considered, too.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
The norm for rectifying imagery is a cubic or bilinear convolution. The
norm for rectifying class rasters is a nearest neighbour. Having nearest
neighbour available is necessary, but adding other forms as command line
options would be ideal.
Angus.
Hi Angus,
Regards
> > Hi again,
> > sources.
> > Markus
