On Fri, Apr 06, 2001 at 01:53:06AM -0300, Fernando Pacheco wrote:
Hello:
I write a function D_translate_color_to_RGB(char *) in
src/libes/display/tran_color.c to translate user input string like
indigo or magenta or grey or 255,0,127 or (((255|0|||127)-- or
somestring255somestring0somestring127somestring to typedef RGB defined
in src/include/color.h then I can use all the colors in vectors
(d.vect) and areas (d.area). I'm sending to you my 2 new files, and a
d.area using the new library function. The function can substitute the
D_translate_color.
I'm not a experience C program but my users like the new colors.
Fernando Pacheco.
Thanks for your effort. Couple things I noticed in your function:
Use of C++ style comments. AFAIK, these are allowed in ISO C99, but
many older compilers will choke. Second (and worse) you are returning a
locally scoped variable. This may work on some systems, but on others
it will (and properly should) cause a segfault:
tran_colr.c: My comments delimited with <comment>...</comment>
/* Take a string in format R|G|B or (R,G,B) or somestringRsomestringGsomestringBsomestring or red or magenta or indigo...,
* and returns the colors numbers in format RGB as short. R=0-255,G=0-255,B=0-255.
*Fernando Pacheco
* fpacheco@dinama.gub.uy
RGB D_translate_color_to_RGB(char *str )
<comment> Make RGB * D_translate_color_to_RGB (char *str) </comment>
int ltotal,cont1,esdigito,color;
char buf[56];
char buftemp="...................";
<comment> ^^^^^^^^^^^^^^^^^^^^^^^^ What is that about? </comment>
char one_char[2];
//typedef RGB is defined in color.h
//D_translate_color_to_RGB is declared in color.h
<comment> Don't use C++ style commenting </comment>
RGB RGB_ret;
<comment> Bad juju here. This variable is local to this function:
Instead:
RGB *RGB_ret = (RGB *) G_malloc (sizeof(RGB));
and use RGB_ret->r (etc...)
</comment>
<comment> SNIP strcmp()'s </comment>
//not a named color then...
ltotal=strlen(str);
strcpy(buf,str);
esdigito=0;
color=0;
for (cont1=0;cont1<ltotal+1;cont1++)
if ((buf[cont1]=='0') || (buf[cont1]=='1') || (buf[cont1]=='2') || (buf[cont1]=='3') || (buf[cont1]=='4') || (buf[cont1]=='5') || (buf[cont1]=='6') || (buf[cont1]=='7') || (buf[cont1]=='8') || (buf[cont1]=='9'))
one_char[0]=buf[cont1];
esdigito=esdigito+1;
buftemp[(esdigito-1)]=one_char[0];
} else {
if (esdigito>0)
color=color+1;
switch (color)
case 1:
RGB_ret.r=atoi(buftemp);
if (RGB_ret.r>255)
RGB_ret.r=255;
break;
case 2:
RGB_ret.g=atoi(buftemp);
if (RGB_ret.g>255)
RGB_ret.g=255;
break;
case 3:
RGB_ret.b=atoi(buftemp);
if (RGB_ret.b>255)
RGB_ret.b=255;
break;
strcpy(buftemp,"...................");
esdigito=0;
return(RGB_ret) ;
<comment>
Consider using strtol() and strtok() for your parsing or sscanf() even.
RGB *RGB_ret;
int r,b,g;
if (sscanf (str, "( %d , %d , %d )", &r, &g, &b) == 3)
/* success */
else if (sscanf (str, "%d | %d | %d", &r, &g, &b) == 3)
/* success */
else
/* failed */
return NULL;
if (!(r >= 0 && r <= 255
&& g >= 0 && g <= 255
&& b >= 0 && b <= 255)
{ /* error */
return NULL;
if (RGB_ret == NULL)
return NULL;
RGB_ret->r = (unsigned short) r;
RGB_ret->g = (unsigned short) g;
RGB_ret->b = (unsigned short) b;
return RGB_ret;
</comment>
Eric G. Miller <egm2@jps.net>
subject 'unsubscribe grass5'
