[GRASS5] Alternate Build Mechanism
I've added an alternate build mechanism, which uses GNU make (maybe
other, but not tested). The main features are:
1. It allows building in a separate directory from the source.
2. It allows the use of a read-only source directory (although write
permission is required to generate the makefiles).
3. It's significantly simpler than the existing mechanism.
Usage instructions are in the file mk/README.
The existing build mechanism should be unaffected.
There is one feature regarding the use of yacc which could use further
testing. In order to allow y.tab.[ch] to be generated in the build
directory, I invoke yacc as:
  $(YACC) -b $(OBJARCH)/y -d foo.y
This works with both "bison -y" and Berkeley yacc, but I'm unsure
about other versions of yacc.
Thanks.
However we should decide for one build system the grass5.0.0
release should use.
It would be nice to have a better one in place for grass5.1.x then.
BTw: Has someone played around with Scons?
http://www.scons.org/
