Maybe this was already on the list that has been discussed, but I’d forgotten about it. g.mremove has a ‘do you really want to do this y/n’ message that causes it to hang in the tcltk GUI. There may be another one or two that do the same thing. Could we just drop this ‘pause to reconsider’ from these commands in exchange for a warning in the description that says something along the lines of “WARNING this command will delete ALL files matching the wildcard specifications!”?
Michael
Arizona State University
Tempe, AZ 85287-2402
USA
Personally, I like the 'is this what you intend to do' message. More than once I have looked at that list and thought, " oh crap... that is not at all what I intended to do". Although I use it on the command line and not through the gui...
Just my 2 cents...
Kirk
Michael
______________________________
USA
Personally, I like the ‘is this what you intend to do’ message. More than once I have looked at that list and thought, " oh crap… that is not at all what I intended to do". Although I use it on the command line and not through the gui…
Just my 2 cents…
Kirk
Michael
USA
Just my 2 cents...
I think the same - many times the "Do you really want to remove this?" saved my life. Please don't remove this functionality neither from GUI nor command line. May lead to disaster and heavy frustration. No apriori warning can replace it.
Maciek
Michael
USA
>Just my 2 cents...
> >Just my 2 cents...
I fully agree.
For the general case "G_ask()" (or whatever it is called) could use a
GUI pop-up window along the same lines as G_percent() when called from
GUI. For scripts, this might be an option of a g.message module (with
return codes for [Yes] [No])?
Maybe getting too complicated for a simple problem.
