On Mon, Jan 02, 2006 at 05:35:40PM +0000, Glynn Clements wrote:
Markus Neteler wrote:
> I have submitting updated function declarations
> to CVS to migrate old K&R style to ANSI style. About
> 800 functions in 230 files are affected.
> This work was only possible thanks to the efforts
> of Prof Giulio Antoniol (École Polytechnique, Montreal,
> Canada) who analyzed the 6.1-CVS code and wrote a PERL
> script for me/us to auto-convert the function
> declarations.
Is there a problem with the "protoize" utility (from gcc)?
I tried a while but didn't get it working and didn't
find instructions online which I managed to understand.
So I asked Giulio Antoniol, and he helped out.
> I am submitting things only after inspection.
> The list of changes (CVS diffs) is available at:
> http://grass.itc.it/pipermail/grass-commit/2006-January/date.html#end
> My gcc flags for compilation are (pretty restrictive):
> MYCFLAGS="-g -Wall -Werror-implicit-function-declaration -fno-common"
> MYCXXFLAGS="-g -Wall"
> CFLAGS="$MYCFLAGS" CXXFLAGS="$MYCXXFLAGS" ./configure ...
> A few doubts I have which I would like to discuss here
> before submitting:
> I fixed (hopefully correctly) the 'wext()' definition
> and calls in
> lib/cdhc/as181.c
Note that, for function arguments, there is no semantic difference
between "double x" and "double *x".
Personally, I always use the latter as what is being passed is a
pointer, but some people like to use the different syntaxes to
indicate whether the pointer points to a single value (*x) or to
multiple values (x).
So far we preserved what was there. It is debatable to
make another round to get this updated as well.
> Then a conflict in lib/gis/:
> definition in gisdefs.h:
> /* index.c */
> char *G_index(char *, int);
> char *G_rindex(char *, int);
> definition in index.c:
> char *
> G_index (register char *str, register char delim)
> char *
> G_rindex (register char *str, register char delim)
Using "register" in argument lists is meaningless. Whether or not a
register is used is determined by the calling convention.
Linux/x86/gcc uses the stack by default; you can force the use of a
register using the "regparm" attribute, but that's seldom a good idea.
For local variables, it's almost always preferable to let the compiler
figure out when to use a register (and most modern compilers will just
ignore "register" specifiers).
This is the patch which I applied, hope that's right:
Index: index.c
RCS /grassrepository/grass6/lib/gis/index.c,v
retrieving revision 2.0
diff -u -r2.0 index.c
--- index.c 9 Nov 2004 12:18:38 -0000 2.0
+++ index.c 3 Jan 2006 06:32:53 -0000
@@ -1,3 +1,5 @@
+/* TODO: should this go into strings.c ? */
#include "gis.h"
@@ -12,8 +14,8 @@
char *
-G_index (str, delim)
- register char *str, delim;
+G_index (char *str, int delim)
while (*str && *str != delim)
str++;
@@ -34,10 +36,10 @@
char *
-G_rindex (str, delim)
+G_rindex (char *str, int delim)
- register char *p;
+ char *p;
p = NULL;
while (*str)
> another one in lib/gis
> /* unctrl.c */
> char *G_unctrl(int);
> definition in unctrl.c
> char *G_unctrl(unsigned char c);
Change the implementation to match the declaration in gisdefs.h. The
K&R version will expect an int to have been passed, as that's the
smallest integral type that K&R allows.
Here's the patch which I applied:
Index: unctrl.c
RCS /grassrepository/grass6/lib/gis/unctrl.c,v
diff -u -r2.0 unctrl.c
--- unctrl.c 9 Nov 2004 12:22:58 -0000 2.0
+++ unctrl.c 3 Jan 2006 06:32:53 -0000
@@ -9,13 +9,13 @@
* represented by ctrl-C, e.g., control A is represented by ctrl-A. 0177 is
* represented by DEL/RUB. Normal characters remain unchanged.
- * \param c
+ * \param int c
* \return char *
char *
-G_unctrl(c)
- unsigned char c;
+G_unctrl (int c)
static char buf[20];
> imagery/open.c
> static error (char *group, char *file, char *msga, char *msgb)
> The compiler complains about absent return type:
> open.c:12: warning: return type defaults to `int'
> open.c: In function `error':
> open.c:17: warning: control reaches end of non-void function
Change it to "static void error(...)".
done.
> Unrelated, I found that by chance:
> bartok:gis[6941.292] grep 'floor()\|ceil()' *
> align_window.c: double floor(), ceil();
> color_range.c: double floor(), ceil();
> I guess that it is no good idea to have it
> defined, right?
Use "#include <math.h>" to get the prototypes.
Done as well.
Thanks, Glynn, for the explanations.
