Hello,
First some context. I try to hide to users most of the "complexity" of
the importation, transformations, cleaning, topology building and so on,
and hence has created 4 scripts aiming to split the work into 4 steps
and asking for user intervention only when necessary (for example to
correct the connection between segments, moving text insertion points
that are too "far" from areas centroids to be automatically associated
with, etc.).
These scripts are adapted by sourcing a resource file that I want to
stand in the Grass data directory.
And the four steps are tracked by touching four empty files (sort of
lock files).
The question is:
- is there any standard location within the Grass database to put this
local stuff in?
At first sight, I wanted to put the "lock" files in the .tmp directory
but, even if this is unlikely, this merge may create problems some day
(for example if one decides that GRASS will high-handed empty the .tmp
directory on exit).
I have after decided to create a "local" directory under the
$GISDBASE/$LOCATION_NAME/$MAPSET and put my local stuff (both
resources and temporary files) here.
I am correct or is there already some policy about this?
Thierry Laronde (Alceste) <tlaronde@polynum.org>
Key fingerprint = 0FF7 E906 FBAF FE95 FD89 250D 52B1 AE95 6006 F40C
