adding /usr/local/gdal/lib to /etc/ld.so.conf and run ldconfig solved the
problem
thanks
Marco
-----Ursprungliche Nachricht-----
Von: grass-de-bounces@grass-verein.de
[mailto:grass-de-bounces@grass-verein.de]Im Auftrag von Stephan Holl
Gesendet: Freitag, 4. Februar 2005 19:15
An: grass-de@grass-verein.de
Betreff: Re: [GRASS-de] problems compiling GRASS on SuSE 8.2
Hello Marco,
On Thu, 3 Feb 2005 14:26:40 +0100 "Marco Lechner"
<marco.lechner@urz.uni-heidelberg.de> wrote:
Hi list,
After hours of compiling with different options I still get this
error-message after starting GRASS and having chosen the
mapset/location:GRASS 6.0.0beta1:/usr/local/grass60/bin > Error in startup script:
ps.map: error while loading shared libraries: libgdal.so.1: cannot
open shared object file: No such file or directory
while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 31)
invoked from within
"main $argc $argv"
(file "/usr/local/grass60//grass-6.0.0beta1/etc/dm/d.m.tcl" line
890)but libgdal.so.1 is in /usr/local/gdal/lib/
libgdal.la libgdal.so libgdal.so.1 libgdal.so.1.6.0
did you add /usr/local/gdal/lib to /etc/ld.so.conf and run ldconfig
afterwards?
This sets the path where the dynamic linker searches for libraries
loaded at runtime...
A few more hints:
I tried compilation with the GRASS 6.0.0beta1 and the CVS-Snapshot
from Jan 25th. with the follwoing options:./configure --with-cxx --with-odbc --with-blas
--with-blas-libs=/usr/lib/ -
-with-lapack --with-motif --with-readline --with-freetype=yes
--with-freety pe-includes=/usr/include/freetype2 --with-mysql
--with-mysql-includes=/usr/i nclude/mysql/ --with-nls
--with-gdal=/usr/local/gdal/bin/gdal-config --with-
postgres-includes=/usr/include/pgsql --with-postgres-libs=/lib/
--with-proj- includes=/usr/local/proj/include/
--with-proj-libs=/usr/local/proj/lib/ --wi th-glw
--with-glw-libs=/usr/local/lib --with-glw-includes=/usr/local/include
--enable-64bit --prefix=/usr/local/grass60./configure
rass60/ --with-postgres-includes=/usr/include/pgsql/
fyi, you should remove the trailing slashes while configuring.
configure works:
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /nfs/u1/software/grass/grass-6.0.0beta1
Build directory: /nfs/u1/software/grass/grass-6.0.0beta1
Installation directory: /usr/local/grass60/grass-6.0.0beta1
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
FORTRAN compiler:
Building shared libraries: yesNVIZ: yes
X11 support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: yes
OpenGL(R) support: yes
ODBC support: yes
FFTW support: yes
BLAS support: yes
LAPACK support: yes
AFAIK blas and lapack are currently used.
Motif support: yes
FreeType support: yes
GLw support: yes
NLS support: yes
Readline support: yes
C++ support: yes
openDWG support: no
GDAL support: yes
OGR support: yesmake has first problems in GRASS_SRC/lib/proj:
GRASS GIS compilation log
Started compilation: Thu Feb 3 14:00:52 CET 2005
Errors in:
/nfs/u1/software/grass/grass-6.0.0beta1/lib/proj
Finished compilation: Thu Feb 3 14:08:56 CET 2005make in ...lib/proj says (no idea):
saone:/u1/software/grass/grass-6.0.0beta1/lib/proj # make
install -m 644 datum.csv gdal_datum.csv projop_wparm.csv ellipsoid.csv
pcs.csv stateplane.csv gcs.csv prime_meridian.csv unit_of_measure.csv
/nfs/u1/software/grass/grass-6.0.0beta1/dist.i686-pc-linux-gnu/etc/og
r_csvif I start make again it works without errors:
Started compilation: Thu Feb 3 14:17:34 CET 2005
Errors in:
Finished compilation: Thu Feb 3 14:18:14 CET 2005:make install goes without problems, but the message on top still
apears.
HTH
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
