[GRASS5] Bad Fifo! - Mac OS X
Jeshua,
Yes, that fifo.1a listing looks correct. And the 'p'
at the start of the permissions indicated that it was
correctly created as a FIFO file.
I think that not all of the needed routines (like
d.mon routines) got recompliled when you updated
io.c. I also think that I should have included that
vital information in my previous email. There are a
lot of grass routines that use the raster library
routines.
To make sure that the routines that need the libraster
updates get recompiled, you can use the README.ipc
script. I have used this to set up the IPC
configuration, but it also has an option to return to
the normal (FIFO) configuration. To do this, in the
grass root dir:
.README.ipc -f orig
That should force everything back to the normal
configuration. Note that this version of README.ipc
has probably not been exhaustively tested. Another
option is to clean up and recompile from scratch, eg.
make clean
make
This will take longer, but should get rid of any code
that's still linked to the IPC version of the raster
library routines.
Hopefully, your next message will tell us of your
success!
Malcolm
--- Jeshua Lacock <jeshua@SierraMaps.com> wrote:
>I'm sorry.
>The code in src/libes/raster/ needs to be updated
as well. You should only
>need to update the io.c file in that directory.
Sorry for the extra work.
>(This is the routine where the error message is
generated - but both this and
>the XDRIVER were changed together).
>Malcolm
>Jeshua Lacock wrote:
>> On Friday, January 26, 2001, at 04:34 PM,
Malcolm Blue wrote:
>> > Please see the messages related to XDRIVER
problems on the list. These
>> > problems were caused by an inadvertent mix of
FIFO and IPC messaging in
>> > the grass libraries and the XDRIVER and the
file types in the dev
>> > directory.
>> > The XDRIVER code has been reinstated, so you
should update the
>> > src/display/devices/XDRIVER directory. After
that it should work for
>> > you.
>> Hi Malcolm,
> > I just updated and compiled, and I get the same
fifo error.
Hi again,
I updated io.c, compiled and got the same error, so
I updated the
whole src/libes/raster/ directory and I still get
the same error:
    /usr/local/grass5/dev/fifo.1a: Operation not
supported
Heres a ls -la of fifo.1a:
    prw-rw-rw- 1 jeshua wheel 0 Jan 25 23:48
Is it normal to be zero bytes?
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development
Team mailing list write to:
subject 'unsubscribe grass5'
_______________________________________________________
Do You Yahoo!?
Get your free @yahoo.ca address at http://mail.yahoo.ca
