[GRASS5] beta8 compilation problem
I'm probably overlooking something silly, but I'm having no luck getting
the latest version to compile under either Solaris 2.6 or 2.5. After
running ./configure with user-owned directories defined, I run
make install
and get the following:
malcolm@cast 32%>>make install
test -d /proj/grass4.1/grass5.0 || mkdir -p -m 755
test -d src/CMD/next_step || mkdir -p src/CMD/next_step
UNIX_BIN=/home/malcolm SRC=`pwd` MAKE=make NAME_VER=`cat src/CMD/VERSION
| head
-1 | sed 's/\..*//'` GISBASE=/proj/grass4.1/grass5.0 MACHINENAME=`uname
-n` /bin/sh src/CMD/generic/CREATE_GMAKE.sh
sh: test: argument expected
*** Error code 1
make: Fatal error: Command failed for target `pre-install'
Any ideas? Much obliged,
  -Malcolm Williamson
   CAST - University of Arkansas
subject 'unsubscribe grass5'
Malcolm,
Check the shell script and see if you have carriage returns in it.
John
----- Original Message -----
To: <grasslist@baylor.edu>
Sent: Tuesday, August 22, 2000 10:24 PM
Subject: [GRASS5] beta8 compilation problem
make install
| head
*** Error code 1
-Malcolm Williamson
to:
