Folks,
Do I remember the agenda correctly? As I recall, the deadline that is upon
us now it the deadline for creating the release branch. Once that is created
there will be no new features added to the branch. There will still be some
time for bug fixing before the actual release, so some code that is currently
broken might actually be fixed before the release. How much time will there
be?
Roger Miller
Correct.
Yes. Note that only release critical bugs shall be fixed then.
I've also noted your proj update as one we want to have finished
before the branching.
How much time will there be?
Between release branching and actual release? It depends.
For the current schedule check:
http://grass.itc.it/pipermail/grass5/2002-April/002477.html
For the procedure also see:
http://grass.itc.it/codemanagement.html
