[GRASS5] Branching for 5.0.0 ahead
Bernhard wrote:
> > Work in progress that I've noticed:
> > - d.zoom Radim
> > - m.in.e00 Michel
> > - proj Roger
> also:
The next two seem to be subprojects of the proj update:
> - m.proj[2] needs the datum update to be synchonized with
[rsv].proj
> (it is easier to explain to users that datum transform is not
there than
> telling them which modules are updated already - which is great
indeed)
> - html pages need update for the nad2nad
The proj library is updated in everything but the make process, which I
think is in Glynn's capable hands.
The module update and changes to the html documentation are done except
for m.proj and m.proj2, both of which should still work as documented.
I'll change those as my schedule permits and let you know.
I think too that something might need to be done with or about
v.in.dlg.scs.
Roger Miller
> > > - d.zoom Radim
> > > - m.in.e00 Michel
> > > - proj Roger
> > also:
> > - m.proj[2] needs the datum update to be synchonized with [rsv].proj
> > (it is easier to explain to users that datum transform is not there than
> > telling them which modules are updated already - which is great indeed)
It should be done, in that the .lla files are being compiled and
stored in $GISBASE/etc/nad.
A couple of issues:
1. Should the ntv1_can.dat file be copied to $GISBASE/etc/nad also?
2. What's the situation with the two-letter files (FL.lla etc)?
According to nad/README (in proj-4.4.5), these are NAD83->NAD83,
whereas the others (e.g. conus.lla) are NAD27->NAD83. Are they meant
to be applied as a "correction" after NAD27->NAD83 conversion?
