[GRASS5] Buffer width.
Hello,
I would like to know if it is possible to set buffer width (v.buffer) based on attributes stored in database file (GRASS 5.7). So far I have set buffer width as a constant value or values.
Jarek.
or could I get some good instructions to build them myself?
thanks
Stephen
run v.buffer buffer=$SIZE + v.patch in a shell loop, or:
d.vect.chart ctype=pie
on a single column of data (ie the size).
Hamish
v.patch is not sufficient for areas, it is better to use
v.overlay olayer=0,1,1
Radim
