this bug's URL: http://intevation.de/rt/webrt?serial_num=1028
Bug report:
A (minor) problem is that the fonts used in d.barscale
are not consistent in PNG driver (CELL driver not tested).
When placing a barscale with d.barscale in a GRASS monitor,
the size of "N" (north) and the number at the right (e.g. 10km)
are consistent. The same settings in PNG driver lead to a
too large number at the right.
See
http://mpa.itc.it/markus/tmp/pngdriver.jpg
Nothing severe, but not nice.
--- Headers Follow ---
From neteler@itc.it Wed Apr 24 14:43:56 2002
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 95E0213922
for <grass-bugs@lists.intevation.de>; Wed, 24 Apr 2002 14:43:56 +0200 (CEST)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by mail.intevation.de (Postfix) with ESMTP id 638521B6D6
for <grass-bugs@intevation.de>; Wed, 24 Apr 2002 14:43:55 +0200 (CEST)
Received: from orchestra.itc.it (orchestra [10.0.10.11])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g3OChsn06252
for <grass-bugs@intevation.de>; Wed, 24 Apr 2002 14:43:54 +0200 (MET DST)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g3OChsK18477
Received: (from neteler@localhost)
by thuille.itc.it. (8.11.6/8.11.2) id g3OChrm14531
for grass-bugs@intevation.de; Wed, 24 Apr 2002 14:43:53 +0200
Date: Wed, 24 Apr 2002 14:43:53 +0200
To: grass-bugs@intevation.de
Subject: PNG driver - d.barscale
Message-ID: <20020424144353.A14513@itc.it>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5.1i
X-Spam-Status: No, hits=0 required=5 tests=
I am unable to reproduce this.
I am also unable to see how this could happen; the text code isn't
part of the individual drivers, it's common to all of them.
Can you provide the region information, and the size of the monitors?
OK, I see what's happened; The PNG monitor is actually significantly
taller than the image which you provided.
The text at the RHS of the bar is text, which is sized as 1/40th of
the frame' height. The North symbol at the LHS is line art, and is
sized in pixels.
I've fixed the text size at 14 pixels.
sized in pixels.
Glynn,
as usual a perfect solution. Thanks,
PS: I'll close the report.
