[GRASS5] [bug #1033] (grass) motif and configure
this bug's URL: http://intevation.de/rt/webrt?serial_num=1033
it seems that there are problems to pick up the
MOTIF/lesstif libs/includes:
configure
checking whether to use Motif... yes
checking for location of Motif includes...
/usr/X11R6/LessTif/Motif1.2/include
checking for Xm/Xm.h... yes
checking for location of Motif library... /usr/X11R6/LessTif/Motif1.2/lib
checking for XmStringCreate in -lXm... yes
so far so nice. But
grep OPEN src/CMD/head/*
src/CMD/head/head.i686-pc-linux-gnu:OPENGLINC =
src/CMD/head/head.i686-pc-linux-gnu:OPENGLwINC =
src/CMD/head/head.i686-pc-linux-gnu:OPENGLLIB = -lGL
src/CMD/head/head.i686-pc-linux-gnu:OPENGLULIB = -lGLU
does not contain the directories. Therefore
r3.showdspf.opengl
does not compile.
--- Headers Follow ---
From neteler@itc.it Mon Apr 29 19:00:57 2002
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id 5DF57139C5
  for <grass-bugs@lists.intevation.de>; Mon, 29 Apr 2002 19:00:57 +0200 (CEST)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
  by mail.intevation.de (Postfix) with ESMTP id 0E1A41B6D6
  for <grass-bugs@intevation.de>; Mon, 29 Apr 2002 19:00:55 +0200 (CEST)
Received: from orchestra.itc.it (orchestra [10.0.10.11])
  by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g3TH0rn05064
  for <grass-bugs@intevation.de>; Mon, 29 Apr 2002 19:00:53 +0200 (MET DST)
Received: from thuille.itc.it. (thuille [10.40.0.110])
  by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g3TH0rK13703
Received: (from neteler@localhost)
  by thuille.itc.it. (8.11.6/8.11.2) id g3TH0rr06147
  for grass-bugs@intevation.de; Mon, 29 Apr 2002 19:00:53 +0200
Date: Mon, 29 Apr 2002 19:00:53 +0200
To: grass-bugs@intevation.de
Subject: motif and configure
Message-ID: <20020429190053.A6139@itc.it>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5.1i
X-Spam-Status: No, hits=0 required=5 tests=
configure
so far so nice. But
1. Are we discussing OpenGL or Motif here?
2. It probably doesn't need any directories. Any program using either
OpenGL or Motif will have to include the appropriate X flags (neither
library will work without X) so, if those libraries are in
/usr/X11R6/lib, no additional switches need to be added by configure.
Given the configure output, I *would* expect to see directories for
the Motif libraries, e.g. something like:
XMLIB = -L/usr/X11R6/LessTif/Motif1.2/lib -lXm
Therefore
r3.showdspf.opengl
does not compile.
3. Or are we discussing the OpenGL widget library (lib*GLw*)? Which is
a separate problem to either OpenGL or Motif.
> configure
> so far so nice. But
Aehm, sorry - I was obviously confused.
> Therefore
> r3.showdspf.opengl
> does not compile.
The MOTIF issue is solved now (I have adjusted the Gmakefile).
Yes, this problem remains (GLwCreateMDrawingArea is needed for compilation):
configure ... --with-glw
checking whether to use GLw... yes
checking for location of GLw includes...
checking for GL/GLwMDrawA.h... yes
checking for location of GLw library...
checking for GLwCreateMDrawingArea in -lGLw... no
checking for GLwCreateM1DrawingArea in -lGLw... no
checking for GLwCreateM2DrawingArea in -lGLw... no
checking for GLwCreateMDrawingArea in -lGLwM... no
checking for GLwCreateM1DrawingArea in -lGLwM... no
checking for GLwCreateM2DrawingArea in -lGLwM... no
configure: error: *** Unable to locate GLwM library.
On my Redhat box is
locate GLw
/usr/share/man/man3/GLwCreateMDrawingArea.3x.gz
/usr/share/man/man3/GLwDrawingArea.3x.gz
/usr/share/man/man3/GLwDrawingAreaMakeCurrent.3x.gz
/usr/share/man/man3/GLwDrawingAreaSwapBuffers.3x.gz
/usr/lib/libMesaGLw.a
/usr/include/GL/GLwDrawA.h
/usr/include/GL/GLwDrawAP.h
/usr/include/GL/GLwMDrawA.h
/usr/include/GL/GLwMDrawAP.h
Hopefully this is of help for you.
On my Redhat box is
locate GLw
[snip]
I'll check for that as well, but does that library include the Motif
widget (use "nm /usr/lib/libMesaGLw.a")? If not, you will need
libMesaGLwM.a.
> On my Redhat box is
> locate GLw
[snip]
libMesaGLwM.a.
No, it is not included in this Redhat 7.1:
  nm /usr/lib/lib*GL*.a |grep GLwCreateM
  -> nothing
So I have to compile libMesaGLwM.a (aarg).
