[GRASS5] [bug #1041] (grass) datum error while building new location
this bug's URL: http://intevation.de/rt/webrt?serial_num=1041
Subject: datum error while building new location
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: cvs_snapshot_exp_2002_05_03
I tried to build a german Gauß-Krüger Location with datum
specification (normally this works fine..)
map datum for this location?(y/n) [n] y -> this skipped the whole projection part and jumped
             directly into the 'region display' , so I used
g.setproj afterwards:
Please specify projection name >tmerc :
Please specify ellipsoid name >bessel :
Do you want to specify a map datum for this location?(y/n) [n] y
-> Speicherzugriffsfehler (memory access error ?).
The same problem appears for UTM , ....
regards
Otto Dassau
regards
Otto Dassau
Thanks for the bug report.
Just tested here (current HEAD) - it also crashes for me.
It seems that the recent upgrade of the PROJ4 (before creating
the release branch) removed some working code.
To avoid that the pre4 release is endangered, I suggest to revert the
PROJ4 update in the release branch (so no NAD support for pre4)
unless the fix is easy to do.
> regards
> Otto Dassau
Same here.
Who said anything about PROJ4?
This is due to my changes to the datum handling, when it was moved
from libcoorcnv to libgis:
  Working file: src/libes/gis/datum.c
  revision 1.1
  date: 2002/04/12 14:09:32; author: glynn; state: Exp;
  Move datum table code (and datum.table) from libcoorcnv to libgis
  Tidy datum table code
I've committed a fix (to both head and release branch).
It's working again - thanks a lot !!
Otto Dassau
