[GRASS5] [bug #1047] (grass) suggestion to solve [rsv].proj initialization problem
I don't think this is a problem any more. The relevant code has been moved
to lib/proj/convert.c in GRASS 6 and is now also used by v.in.ogr and g.proj
as well as r.in.gdal. It works around this problem by simply not writing an
ellps name into the PROJ_INFO and only puts a and es parameters instead, I
think.
Resolved.
Paul
