[GRASS5] [bug #1052] (grass) [rsv].proj are crashing
this bug's URL: http://intevation.de/rt/webrt?serial_num=1052
Subject: [rsv].proj are crashing
A critical bug report:
v.proj in=austria loca=europa mapset=europa
Segmentation fault (core dumped)
Also r.proj (and eventually s.proj, untested) are affected.
I have spent some time in src/libes/gis/env.c where the crash occurs
in line 195 of get_env() function. The reason is unclear to me why
strcmp() crashes sometimes (maybe someone else understands the
problem).
This should be fixed before pre5.
problem).
If strcmp() crashes, one of its arguments is invalid, in the sense
that either:
a) it points to an invalid address (e.g. NULL), or
b) it points to a valid address, but scanning the string reaches an
invalid address before it reads a terminating NUL byte.
So, something is passing bad values to strcmp(). In this instance,
either the "environment" is bad, or the caller is passing a bad "name"
argument to G_getenv() or similar.
problem).
r.proj at least does these dubious thing:
   strncpy (in_datum, G_database_datum_name(), sizeof(in_datum));
   strncpy (in_ellipse, G_database_ellipse_name(), sizeof(in_ellipse));
Since both the datum and ellipse functions can return NULL, strncpy
will invoke undefined behavior in those cases. For me, the segfault
in r.proj disappears, by handling these better.
Now, if I can figure out why "1" is returned as the projection name for
UTM...
Eric G. Miller <egm2@jps.net>
UTM...
Sounds like some artifact from old times is playing in here. UTM was one
of the few possible projection types in grass before proj was integrated
and the type 99 'other' was added. But even if proj can handle UTM, you
still find 'wrappers' here and there in the code that will give UTM
projection special treatment, i.e not passing it to proj at all, but
using the old code. Maybe the "1" is a response from some old stuff.
Morten Hulden
