this bug's URL: http://intevation.de/rt/webrt?serial_num=1068
I'm generating a dtm, the process works and the raster map
is ok, but while finishing a warning occours:
WARNING: Invalid timestamp specified for raster
map pcelev in mapset pcansi
using v.surf.rst.
What can it be?
Thanks, Michele.
--- Headers Follow ---
From neteler@itc.it Thu May 30 09:50:52 2002
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 071A113965
for <grass-bugs@lists.intevation.de>; Thu, 30 May 2002 09:50:52 +0200 (CEST)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by mail.intevation.de (Postfix) with ESMTP id 261E41B6D6
for <grass-bugs@intevation.de>; Thu, 30 May 2002 09:50:51 +0200 (CEST)
Received: from orchestra.itc.it (orchestra [10.0.10.11])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g4U7oon14295
for <grass-bugs@intevation.de>; Thu, 30 May 2002 09:50:50 +0200 (MET DST)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g4U7onK20626
for <grass-bugs@intevation.de>; Thu, 30 May 2002 09:50:49 +0200
Received: (from neteler@localhost)
by thuille.itc.it. (8.11.6/8.11.2) id g4U7onL30735
for grass-bugs@intevation.de; Thu, 30 May 2002 09:50:49 +0200
Resent-Message-Id: <200205300750.g4U7onL30735@thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g4U7OaK18796;
Thu, 30 May 2002 09:24:36 +0200
Received: from ccis01.baylor.edu (ccis01.baylor.edu [129.62.1.18])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g4U7OYn13597;
Thu, 30 May 2002 09:24:34 +0200 (MET DST)
Received: from localhost (localhost [127.0.0.1])
by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id CAA1087764;
Thu, 30 May 2002 02:20:07 -0500 (CDT)
Received: from FS-EXCHANGE1.baylor.edu (flopsy.baylor.edu [129.62.3.249])
by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id CAA1104168
for <GRASSLIST@listproc.baylor.edu>; Thu, 30 May 2002 02:16:56 -0500 (CDT)
Received: from waylon.baylor.edu ([129.62.3.228]) by FS-EXCHANGE1.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
Thu, 30 May 2002 02:13:47 -0500
Received: from its07.baylor.edu ([129.62.3.167]) by waylon.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
Thu, 30 May 2002 02:13:46 -0500
Received: from willie.baylor.edu (willie.baylor.edu [129.62.3.227])
by its07.baylor.edu (Switch-2.1.1/Switch-2.1.1) with SMTP id U4U71DA820715
for <GRASSLIST@baylor.edu>; Thu, 30 May 2002 02:13:46 -0500
Received: from smtp2.libero.it ([193.70.192.52])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002053002134503697
Received: from libero.it (193.70.192.46) by smtp2.libero.it (6.5.015)
id 3CECCE9200089DED for GRASSLIST@baylor.edu; Thu, 30 May 2002 09:15:15 +0200
Date: Thu, 30 May 2002 09:15:16 +0200
Message-Id: <GWWXHG$9985B971266C19CA72488A278591521A@libero.it>
Subject: [GRASSLIST:3791] =?iso-8859-1?Q?Strange_(for_me)_WARNING.?=
MIME-Version: 1.0
Content-Type: text/plain; charset=iso-8859-1
From: "=?iso-8859-1?Q?michele.rocc@libero.it?=" <michele.rocc@libero.it>
To: "=?utf-8?Q?grass?=" <GRASSLIST@baylor.edu>
X-XaM3-API-Version: 3.0.1build13 R13
X-type: 0
X-SenderIP: 147.162.117.183
X-OriginalArrivalTime: 30 May 2002 07:13:46.0696 (UTC) FILETIME=[8A0FE480:01C207A9]
Content-Transfer-Encoding: 8bit
X-MIME-Autoconverted: from base64 to 8bit by ccis01.baylor.edu id CAA1063680
Sender: owner-GRASSLIST@baylor.edu
X-Listprocessor-Version: 8.2.10/991025/16:55 -- ListProc(tm) by CREN
Resent-From: neteler@itc.it
Resent-Date: Thu, 30 May 2002 09:50:49 +0200
Resent-To: grass-bugs@intevation.de
X-Spam-Status: No, hits=2.4 required=5.0 tests=FROM_NAME_EQ_FROM_ADDR version=2.20
X-Spam-Level: **
