[GRASS5] [bug #1075] (grass) bug in r.mapcalc
this bug's URL: http://intevation.de/rt/webrt?serial_num=1075
Subject: bug in r.mapcalc
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: grass50_exp_2002_04_26
Hello,
I have found that r.mapcalc doesn't work properly in a prompt/interactive mode:
GRASS:~ > r.mapcalc
mapcalc> newmap=2 * 3
mapcalc> exit
mapcalc>
GRASS:~ > d.rast newmap
ERROR: Raster map [newmap] not available
Problem #1: "exit" doesn't work, I had to use Ctrl-c
Problem #2: newmap was not created
Problem #3 (or just a note): in a command mode, r.mapcalc behaves differently than a few months ago. Now you must have a command without spaces around "="
while in the past this command worked OK:
GRASS:~ > r.mapcalc flow.dx = "flow * cos(aspect)"
r.mapcalc - Raster map layer data calculator
usage: r.mapcalc '<map>=<expression>'
r.mapcalc performs arithmetic on raster map layers.
New raster map layers can be created which are arithmetic expressions
involving existing raster map layers, integer or floating point constants,
and functions.
For more information use 'g.manual r.mapcalc'
So now I have to change my scripts, but it is not a big deal...
Best regards,
Jaro Hofierka
GRASS:~ > r.mapcalc
mapcalc> exit
mapcalc>
Ctrl-C sends SIGINT to the foreground process, which kills it. If you
want to generate an end-of-file condition under Unix, type Ctrl-D.
This will work for r.mapcalc, as does typing a blank line (this is the
method which is documented in the r.mapcalc manpage).
You killed r.mapcalc while it was still reading the expression.
without spaces around "=" while in the past this command worked OK:
I can implement that easily enough.
However, given that you have to quote most of the command (e.g. to
prevent '*' being expanded by the shell), you may as well just quote
the whole thing, i.e.
  r.mapcalc "flow.dx = flow * cos(aspect)"
[Actually, single quotes are preferable.]
Thanks Glynn. This saves us from rewriting lots of scripts and
docs. I just tested:
GRASS:~/cvsgrass_exp > r.mapcalc test="34-43"
test = (sub(34,43))
   3%...
GRASS:~/cvsgrass_exp > r.mapcalc "test=34-43"
test = (sub(34,43))
   3%...
nice.
Really? For my bash it works:
r.mapcalc test="34 * 43"
test = (mul(34,43))
test = (sub(34,43))
   3%...
test = (sub(34,43))
   3%...
nice.
Er, that's just shell behaviour; in both cases, r.mapcalc will get a
single argument.
test = (mul(34,43))
Same here, this is still a single argument.
The issue was regarding unquoted spaces in the command line, e.g.:
  r.mapcalc test = "34 * 34"
In this case, r.mapcalc would get three arguments, i.e.
  argc: 4
  argv[0]: "r.mapcalc"
  argv[1]: "test"
  argv[2]: "="
  argv[3]: "34 * 34"
The fix duplicates the behaviour of the old r.mapcalc which, when
given multiple arguments, concatenates them into a single string, then
parses that string.
