[GRASS5] [bug #1101] (grass) GUI (tcltk) does not run
this bug's URL: http://intevation.de/rt/webrt?serial_num=1101
Subject: GUI (tcltk) does not run
Platform: other
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 50pre4
This is the result after the command tcltkgrass&:
[1] 667
        Mapset <PERMANENT> in
Location <spearfish> GRASS 5.0.0pre4 > Error in
startup script: can't read "env(TCLTKGRASSBASE)": no such variable
    while executing
"subst $monitors_menu"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 subst $element"
    (procedure "menu_build" line 28)
    invoked from within
"menu_build 0 $menupath $element"
    (procedure "menu_build" line 61)
    invoked from within
"menu_build 1 .main_menu {
    Config "Configuration of TclTkGRASS" {
        Monitors "" $monitors_menu
        "Module windows" "" {
            "Aut..."
    (file "/usr/local/grass5/tcltkgrass/main/menu.tcl" line 232)
    invoked from within
"source $env(TCLTKGRASSBASE)/main/menu.tcl
    (file "/usr/local/grass5/bin/tcltkgrass" line 22)
c
