[GRASS5] [bug #1125] (grass) "make install" fails trying to copy "locale"
this bug's URL: http://intevation.de/rt/webrt?serial_num=1125
Subject: "make install" fails trying to copy "locale"
Platform: Solaris2.X/Sparc
grass obtained from: Trento Italy site
GRASS Version: 5.0pre4
Please enter error description here (and your name)
To get the "make install" to succeed, had to comment out this line (in the "real-install" target):
        #test -d ${GISBASE}/locale && ${SHELL} -c "cd ${GISBASE} ; tar cBf - locale | (cd ${INST_DIR} ; tar xBf - ) 2>/dev/null ; true"
And indeed, "locale" is not present in directory "GISBASE".
This is the sort of bug that would make a potential new user quickly give up and walk away from GRASS. The build process for a mainstream OS like Solaris should be flawless.
Non-defaults: no ODBC or Postgres, included FFTW, GDAL, TCL/TK
Hal Mueller
Known bug on all platforms. Fixed in pre5.
