this bug's URL: http://intevation.de/rt/webrt?serial_num=1170
Subject: m.in.e00 segmentation faults
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 5.0pre4
I've been trying to import some fairly large binary arc export files. Files with only point coverages produced a segmentation fault with "action=all" (which is the default.) but succeeded with "action=vector." Using m.in.e00 to import a very large (300+ MB) file with polygon coverage produced a segmentation fault immediately after writing the last dig_cats file. "action=analyse" revealed no problems. With a smaller (70+ MB) file with a polygon coverage m.in.e00 created all of the dig_cats files but ran very slowly trying to import the vector map. It ran for approximately 4 hours and was about 80% done before the OS killed the process.
Importing a point coverage produced a site file with locations and numeric codes identifying the sites, but brought in no other attribute values, which made the site files nearly useless.
Roger Miller
rgrmill@rt66.com
